Wastegate ?'s
Old Jul 12, 2005 | 12:26 AM
hotmopr's Avatar
Wastegate ?'s
I have a turbo that I have been tinkering with. It is wastegated and I was wondering If I was to bypass the wastgate for testing, how do I wanna do that? Do you wire it open or closed and how can you tell with it on the bench? I have blown air through it with the air compressor and can definitely tell a difference when I actuate the lever, Just not sure which way it goes.. Last ? Is there a way to make a turbo that may be to large spool faster without buying new exhaust housings ect...? It already has a 17 cm2 housing on it and thats as small as I have found..
Old Jul 12, 2005 | 02:24 AM
Jambbii's Avatar
You want it closed. Couldnt you just block off the vacum signal to it to make it stay closed?
Old Jul 12, 2005 | 05:26 PM
hotmopr's Avatar
Could, But I removed the actuator and the arm for clearance.
Old Jul 12, 2005 | 06:01 PM
Jambbii's Avatar
Is this the WH2D that I tried to get you are working on?
Old Jul 13, 2005 | 12:20 AM
hotmopr's Avatar
yeah. It's just to big for a single. So now I am gonna twin it...It's just a hair smaller that HT3B so it should spool really quick.. HOPEFULLY..
Old Jul 13, 2005 | 02:20 AM
Jambbii's Avatar
My buddy is running an h2d as a single daily driver. Pretty laggy but supposidly when the turbo is lit it hauls.
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
dieselcrazy
Mar 22, 2003 08:21 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
