Wastegate plugged
Old Mar 9, 2005 | 10:22 PM
caleb c.'s Avatar
Wastegate plugged
Well I was looking at my new truck the other day and noticed that the wastegate hose had been plugged up by the po.I don't know if I should leave it or enable it again.I t has not ever had any performance mods so I don't really know why it is plugged.Should I leave it?
Old Mar 9, 2005 | 11:03 PM
Big Smoky's Avatar
I don't think it will hurt anything right now since you don't have any mods yet. When you start blowin smoke though you might want to watch the boost gauge.
Eric
Old Mar 9, 2005 | 11:47 PM
Beast2B's Avatar
If there are no mods, with a plugged wastegate hose you should set an overboost code. I know I did when I sent my Comp back for the Drag upgrade. Just the boost elbow and driving like an angel I still set a code. No gauges yet I assume, be nice to know what boost you're seeing...
Old Mar 10, 2005 | 01:15 AM
BDR2500's Avatar
Not tryin to steal the thread, but I have a quick question. So is it bad to have the waste gate blocked off with mods? Should I take my J-hook off with my mods?
Old Mar 10, 2005 | 08:50 AM
CTD NUT's Avatar
It is only bad to have the wastegate blocked if you are boosting well in excess of 35 psi with the stock HY35 on your truck.........35 psi is probably past the ideal boost limit of the 9cm housing but is ok for a HX35........boosting past 35 psi results in a superheated air charge from an overspeeding turbo that raises the psi and will cause an egt rise......occasional spikes past 35 psi are fine......
Old Mar 10, 2005 | 09:39 AM
caleb c.'s Avatar
What is the purpose of plugging the wastegate on a stock truck?I am just trying to figure out why he did it.
Old Mar 10, 2005 | 10:14 AM
CTD NUT's Avatar
There is no purpose on a stock 24v to block the wastegate.......no power gains - just the over boost code, the ecm will defuel in an overboost condition.......with a fueling box with a boost fooler, you could block the wastegate instead of using the boost elbow.......probably no power gain over the boost elbow, though.
Old Mar 10, 2005 | 10:20 AM
caleb c.'s Avatar
Should I hook it back up?
Old Mar 10, 2005 | 10:49 AM
CTD NUT's Avatar
Yes, hook it back up.....until you add additional fueling with a boost fooler, at least.
Old Mar 10, 2005 | 11:14 AM
tool's Avatar
There wasn't a boost fooler allready installed was there???
If he had a boost fooler and the waste gate plugged I guess he'd be making a little more power, he'd continue boosting and the trruck would continue to fuel.
Have you checked it for codes?? If the waste gate is plugged there should be an overboost code as mentioned.
Will the Code affect his engine performance?? I just erased an overboost code from my truck last week, it hasn't come back yet. maybe I'm crazy but it seems to run a little better since?
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
jfpointer
Dec 4, 2002 06:41 AM
20
Nov 20, 2002 08:13 PM
