Wastegate
Old Apr 6, 2004 | 11:55 PM
CanuckCTD's Avatar
Wastegate
Hey Guys,
Is Banks the best place to get a new wastegate? I had a boost test done on my truck and they noted that the wastegate wasn't working properly, so I need to get a new one. Come on guys give me your opinions!!!!
TIA
Old Apr 7, 2004 | 10:48 AM
infidel's Avatar
Don't replace it just yet.
Most of the time the reason the wastegate isn't working is because the line going to it has fallen down too close to the manifold and melted shut, easy fix with new hose. Other times the wastegate is just carboned up and needs to be worked back and forth to break it loose.
Sometimes if a unknowing person tests the wastegate by using compressed air to move it they will blow out the diaphragm with too much pressure. Then you do have to replace it.
Old Apr 7, 2004 | 11:06 AM
INJECTOR JACK's Avatar
Wastegate
I see your from BC also try Peirs Diesel or BD diesel they are both in BC also They will have the parts you aare looking for!
Old Apr 7, 2004 | 11:27 AM
JFellman's Avatar
If the wastegate actuator is infact bad...you can purchase a Turbo Master actuator that is advertised on this site. I have one and it works perfectly. It would also be easy to rig up a simple adjusable spring to keep the wastegate closed untill the desired boost level is reached...thats all that the Turbo Master does. The spring on the Turbo Master is quite easy to compress by the way.
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
dieselcrazy
Mar 22, 2003 08:21 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
