Wastegate
Old Oct 7, 2008 | 09:36 AM
CTD01's Avatar
Wastegate
I just got an htt 66/71/13. How can I wastegate it down to about 50psi? Do I have to change the spring in the waste gate? TIA,
Paul
Old Oct 7, 2008 | 12:46 PM
98.5Hotrod's Avatar
Adjust the wastegate rod, make it longer for less boost. Shorter for more boost.
Old Oct 7, 2008 | 12:48 PM
CTD01's Avatar
Ok ill try that but if the spring pops off at say 60 psi the rod will never move.
Old Oct 7, 2008 | 01:02 PM
dieselrob's Avatar
Mine was set at 45 from them.
Old Oct 7, 2008 | 01:07 PM
scottsjeeprolet's Avatar
Just set your Pulse to 60psi boost.
Old Oct 7, 2008 | 02:07 PM
CTD01's Avatar
I want 50 with no defuel
Old Oct 7, 2008 | 09:26 PM
98.5Hotrod's Avatar
CTD01, maybe I'm having a brain fart but I don't know what you mean by if the spring jumps off.
Old Oct 7, 2008 | 10:14 PM
CTD01's Avatar
There is a spring in the wastegate pot. if that spring takes 60 psi to make the rod move then do I have to get a different pot? Im guna try the rod adjustment tommorow. Thanks
Paul
Old Oct 8, 2008 | 12:39 AM
Big Blue24's Avatar
The rod is adjusted and preloads the spring. You can loosen the rod to the point that you won't make any boost. It will be a little touchy to get it just right, but I'd try two turns looser if I were you.
Old Oct 8, 2008 | 07:45 AM
CTD01's Avatar
Ok thanks guys.
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
dieselcrazy
Mar 22, 2003 08:21 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
