want some more power
Old Jan 28, 2005 | 09:01 AM
diesel_burner's Avatar
hey everyone,
i'm pretty new on this site found it while oversea's. but anyway i'm looking for some power upgrades for my pickup. i've been reading a lot about what everyone has done to there pickups and i was wondering how to get my power up to about 350-400 hp and 600-800 on the tq. another thing i have notices is that nobody seems to have banks product in there pickups. but anyway i would appreciate your advise.
thanks
Old Jan 28, 2005 | 10:32 AM
RowJ's Avatar
Welcome Home!
-Set of Mach 2 injectors...http://mysite.verizon.net/res06gkt/page1.html
-Box of your choice....TST PM3...or an Edge Comp
http://www.tstproducts.com/
http://www.edgeproductsinc.com/dodge.html
These will get you to 400 hp, with controllability from the box (300-400 hp)
Of course you will need gauges, more air in...and more air out! And a new clutch at some point.
Check classifieds in header...some good buys there.
RJ
PS-I've never tried Banks stuff but many members seem to feel you can get more bang for your buck from other suppliers.
Old Jan 28, 2005 | 10:52 AM
Bob Wagner's Avatar
rjohnson, don has a new web address that is way more up to date, you might want to update your bookmark
http://www.f1diesel.com
Old Jan 28, 2005 | 11:07 AM
RowJ's Avatar
Bob - Thanks!
PM'ed you a while ago.
RJ
Old Jan 28, 2005 | 01:06 PM
HOHN's Avatar
Originally posted by rjohnson
Welcome Home!
RJ
I'd second these EXACT recommendations, only I'd favor the Mach 1.5s over the Mach 2s. A little less heat and more MPG.
I'd also add that the TST excels in some cases, and the Edge is better in others. If you are thinking about towing, and towing HEAVY-- then get the TST. If not, the Edge will be great.
I'd suggest you stick to the 350hp point or thereabouts. This HP point is about the best bang/buck. At this point, you can keep the stock air intake (or go BHAF), and your stock exhaust is plenty. You can also stretch your stock turbo to this point. Sometimes your stock clutch will even hold-- mine did.
Consider this:
350hp= Comp (at lower levels) Mach 1.5s, and possible clutch= ~$1350--$2250
430hp= Comp, Mach 2s, hybrid turbo, fuel line kit, clutch, exhaust, and aftermarket intake= ($650+$800+$950+$120+$900+$400+$220)= $4040!
The first 100hp is the cheapest by far!
Justin
Old Jan 28, 2005 | 01:19 PM
caper's Avatar
Question for ya Hohn off topic. I notice you have d25s with no axle disconnect ,are you getting any vibrations from the front drive shaft ??Thanks
Old Jan 28, 2005 | 01:22 PM
HOHN's Avatar
None. I "broke in" my springs a bit though, so they have sagged about 1/2" and that reduces the anglularity.
Shoulda gone with KORE springs. Live and learn, I guess.
JLH
kyle_truck_pull
Oct 29, 2008 02:35 PM
deputydog140
Dec 14, 2006 04:07 AM
hotdram
Dec 21, 2005 06:20 PM
Rockyhud
Mar 7, 2005 06:10 PM
BigNutt
Jan 19, 2004 11:48 AM
