Vulcan kit on an 02 ????
Any one install a vulcan relocate kit on an 02 and have any pics of the filter housing. Cant see that there is enough room to put it on. Thanks
Yes just wondering if there is enough room for the fittings, also I have my guage fitting going into the bottom of the canister with SS line and a snubber valve , not sure I have enough to reach to splice into after the Canister would splicing behind the canister be ok for fuel pressure.
The Vulcan kit works fine on an 02.
I have the fuel pressure tap coming off the bottom just like you want to do. I use a stanless braided line also.
Easiest way to put it all together is pull the canister right off the motor and assemble everything. Put it back on and hook up to the VP.
SilverRam01
Jul 31, 2005 03:35 PM
SuperDave4x4
Jul 9, 2005 02:49 PM
