vp44 to cp3
Old Mar 4, 2007 | 11:16 PM
Munchies's Avatar
vp44 to cp3
Bring on the hate!
I want to grab a CR head and do twin cp3's. Get rid of the meak vp44. Ive been building a great truck around the motor, and now its ready for power. The twin cp3 guys are at about 800hp and they can keep that cool and driveable.
DonM bring it on!
Old Mar 4, 2007 | 11:19 PM
1-5-3-6-2-4's Avatar
they're 2 totally different fuel delivery systems. you're better off to swap in a whole common rail engine and ECM
Old Mar 4, 2007 | 11:20 PM
Muddin_dude06's Avatar
I think the electronics part of it would be a pain to do, why not grab a P-7100 and get it tricked out at a pump shop? Although a CP3 would be cool and VERY ... UNIQUE!
Old Mar 5, 2007 | 01:06 AM
Munchies's Avatar
I think swapping in the fuel deliver parts that i would obviously need to connect the cp3 to the head, would be owrth it.
It will need o-rings and studs anyhow, so what the heck ya know?
Old Mar 5, 2007 | 06:27 AM
displacedtexan's Avatar
Couldn't hurt to try.
But you would need the whole rail, probably the CR injectors, and the ECM...
Old Mar 5, 2007 | 07:56 AM
Tiger Rag's Avatar
CP3 pumps don't do timing, it is done by the electronic injector contols. I'd think you'd have to swap the whole engine, ecm, electronics, etc, etc as mentioned before.
Old Mar 5, 2007 | 08:05 AM
Diesel-Dan's Avatar
I have seen running complete engines as low as 5K.....you would be almost nuts not to take advantage of that considering the resale value of your own engine......Cummins already did the swap for ya…..
Old Mar 5, 2007 | 08:30 AM
mcoleman's Avatar
I'm planning on swapping to a Common rail engine myself when the current engine starts getting tired. They should be well over 1000hp on fuel by then. I like the electronic adjustability and the quicker spool of the CR engines.
Old Mar 5, 2007 | 08:55 AM
SR_Crewchief's Avatar
As I recall, another member swapped a CR engine (last year?) and had issues with the clearance of the ECM and the crossmember.
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
