Voltage Drop / Lights Dimming on Cold Start
Old Jul 5, 2014 | 09:32 PM
  #61
hzemax's Avatar
10 Year Member
And it is against the law to run on idle more than 5 min on -5 degrees celcius or 15 minutes over -5 degrees.
Live with that.
I let my Cummins run high idle about halfnhour during wintertime.
Old Jul 5, 2014 | 09:43 PM
  #62
hzemax's Avatar
10 Year Member
Sorry that im such an idiot , im an european. Sorry.
Old Apr 13, 2016 | 05:16 PM
  #63
Chasegdavis's Avatar
If this describes what you're experiencing when lighting off the Cummins on these frosty mornings,.......
Don't worry, it's normal.
The Cummins uses a pair of 12 volt grid heaters in the intake tract
(imagine two large toaster elements glowing bright red)
that preheat incoming air for easier combustion.
The Ford & Chevy use glow plugs inside the combustion chamber.
As the relay cycles the grids on & off, the large amp draw causes the volt meter reading to drop, and the lights to dim when the relay turns on the juice.
The relay timer will turn off the heaters when the intake temps hit a preset limit, or when the vehicle exceeds a preset MPH (usually between 15-25 mph). edit
Don't panic
.........just another of the experiences you can chalk up to being a member of the Cummins Club.
My voltage drops when I press the gas and comes back up when I let off only at cold start can't figure this out any ideas
Old Dec 16, 2025 | 08:28 PM
  #64
RedLegg's Avatar
Battery Tender
I noticed the drop in voltage and the slow start as soon as I got my truck. I put a Battery Tender on it nearly every day and the problem went away. Maybe its not so noticeable when the battery is kept at full charge?
Mr.Dodgeman
Jan 2, 2008 06:35 PM
Shovelhead
0
Oct 25, 2006 06:21 AM
Shovelhead
0
Oct 18, 2006 05:57 PM
Shovelhead
Dec 24, 2003 03:35 PM
