van aaken stacked on a superchips
Old Feb 15, 2005 | 10:16 PM
high country's Avatar
Thumbs up van aaken stacked on a superchips
just came in from the test run well the superchips is no race winner but it does give the 24v a big kick in the shorts off the line while in perf tow mode, and the van aaken v5, yep not the hottest either, but they work real well together so far....
Old Feb 16, 2005 | 09:19 AM
Bob Wagner's Avatar
you might be surprised if you put it on a dyno, with and without the superchips
Old Feb 16, 2005 | 12:11 PM
TurboPirate24v's Avatar
I've heard EGTs can get high with a box and a superchips stacked.
I'm not one to talk, cause I don't have any guages either....
But...you may want to only give it hell with rest periods in between
Old Feb 16, 2005 | 12:27 PM
Dieselcamper's Avatar
Don't both of those advance timing.Do you hear any increase
in engine noise under load.
Old Feb 16, 2005 | 08:19 PM
It does not seem to change engine noise much, mileage is improving, and the superchips alone did a good job alone getting this pig out of the hole, they really are not much on the top but sub 2200 it pulls much harder, adding the van aaken did add the boost fooler which I wanted and for the $150 i paid for it it was a bargain. I doubt if it will lift the head but time will tell.
ramfreak01
Mar 30, 2008 01:17 PM
IntakeRacing
Feb 11, 2007 08:10 AM
stock03
Nov 15, 2006 01:03 AM
tthomass
19
Aug 6, 2005 10:53 AM
doug
Apr 26, 2004 12:23 PM
