Using existing exhaust for single stack set up?
Old Jan 22, 2008 | 01:28 PM
Txwelder's Avatar
Has anyone used their existing exhaust pieces for the plumbing up to and out of the bed for a single stack set up? What I mean is, has anyone cut up the piece that routes over the axle to get up through the bed? I already have my stack pipe just need to get it all routed to the bed.
Old Jan 22, 2008 | 03:04 PM
logskidder's Avatar
If you can get 2 90* elbows......... I would say yes sir.
Old Jan 22, 2008 | 03:06 PM
logskidder's Avatar
Thats a great idea BTW.
Old Jan 22, 2008 | 04:02 PM
cumminsdriver635's Avatar
If you have a shop saw you can make the elbows yourself. cut a 45* angle on each piece, weld em together, and you have a 90*. I had to make 2 of mine that way. Depending on if you put your stack in the middle or to the side will change the pipe you need. If you go straight up from the exhaust, you just need one elbow. If you go to the corner it can be tricky. I had to go behind the front bed support and then come forward with my pipe. Took a little cutting and welding but not too bad.
Old Jan 22, 2008 | 05:16 PM
logskidder's Avatar
Might get 2 90's out of the tail pipe.....I think thats what he wants to do.
Old Jan 23, 2008 | 12:58 AM
Uploaded these. First pic is facing from the front of the truck back. You can see the welds. And I thought i had made 2 90's, but i only made one as you can see.
Old Jan 23, 2008 | 12:59 AM
From the bed
Valv
Aug 5, 2007 12:51 AM
sluggo42
Nov 21, 2006 03:12 PM
95RAM111
Nov 11, 2003 02:32 PM
Blast54
Nov 2, 2003 01:46 AM
