Upgrades
Upgrades
Last Tuesday we installed my pod and gauges. Upon cranking the truck noticed I had very little fuel pressure, 6 psi at idle. Decided to check on getting a new lift pump, as my RV275's had arrived. Ended up getting the lift pump under warranty. on Thursday installed the new lift pump (long story) Injectors and the Edge EZ. Started at 6:30 PM went home at 9:15 PM. This included two test drives. Very noticable power increase. My driving is 30miles to work on the hwy. then city driving during the day (anywhere from 2-15 miles per day) back home and a ride through the pastures in the evenings. My fuel milage was averaging 16.8 mpg, now it is up to 20.3 mpg. Hard to believe that the fuel milage goes up that much. It is also hard to believe that Dodge has these engines so detuned.
Re:Upgrades
If you're useing the computer for mileage, it is way off with injectors or box added. (not that accurate stock either)<br><br>This is one of the signs to the dealer that you've futzed with stuff.<br><br>If figureing by hand, that is a great increase, I've heard of 2mpg increase, but over 4
.<br><br><br>phox
.<br><br><br>phox
Re:Upgrades
I don't have injectors but when I added my EZ I noticed about a 1-2mpg increase. I think if I could keep my foot out of it, it may get a little better...but that's no fun ;D
Re:Upgrades
Pics of BKay's install will be up here shortly... trying to shrink the file size for the pics, anyone know a good way to do that?<br><br>Possibly will be writing an article on injector install if Jack will have it
<br><br>
<br><br>
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:Upgrades
We've been seeing an average gain of 1.5 with an EZ, and 1 with RV275s. I did have 2 98.5 autos who gained 5 mpg (imperial gallons. Closer to 4 MPUSG), but these were early release trucks that were suffering with extremely poor fuel mileage caused by a reflash early in the life of the truck. Anyone else remember this? Early 98.5s had great power, and fuel mileage almost equal to the 12 valves they replaced, and after a certain reflash, mileage dropped in the toilet and power went wayyyyy down. No matter how many reflashes Chrysler did after that, the trucks never came back. The EZs seem to help these trucks out alot for some reason.<br><br>Rod
Re:Upgrades
[quote author=Push Rod link=board=7;threadid=6195;start=0#57479 date=1035565194]<br>...Early 98.5s had great power, and fuel mileage almost equal to the 12 valves they replaced, and after a certain reflash, mileage dropped in the toilet and power went wayyyyy down. No matter how many reflashes Chrysler did after that, the trucks never came back. The EZs seem to help these trucks out alot for some reason.<br><br>Rod<br>[/quote]<br><br>Rod, know any dates for those early 98.5s and what was the reflash for? Mine has a sticker for a reflash or something. Will check this over the weekend and also look at engine plate to determine date of manufacture. Mine is getting over 17 mpg since I took my slide in camper off and lost my muffler. Could it be one of the ones you're talking about?<br><br>CR
Re:Upgrades
With the BullyDog 8's I'm using, my MPG readout says I'm getting 25-26mph. It's about 10 MPG off. With each fueling increase, it gets further off. I speculate that the ECM has been precalculated for the fuel flow of the stock injectors at given RPM and boost levels to make the calculation.
Re:Upgrades
[quote author=cr1998 link=board=7;threadid=6195;start=0#57545 date=1035575291]<br>[quote author=Push Rod link=board=7;threadid=6195;start=0#57479 date=1035565194]<br>...Early 98.5s had great power, and fuel mileage almost equal to the 12 valves they replaced, and after a certain reflash, mileage dropped in the toilet and power went wayyyyy down. No matter how many reflashes Chrysler did after that, the trucks never came back. The EZs seem to help these trucks out alot for some reason.<br><br>Rod<br>[/quote]<br><br>Rod, know any dates for those early 98.5s and what was the reflash for? Mine has a sticker for a reflash or something. Will check this over the weekend and also look at engine plate to determine date of manufacture. Mine is getting over 17 mpg since I took my slide in camper off and lost my muffler. Could it be one of the ones you're talking about?<br><br>CR<br>[/quote]<br><br><br>Checked today and the sticker says "Reprogram ECM". Also, manufacture date is 2-5-98.<br><br>CR
Re:Upgrades
[quote author=cr1998 link=board=7;threadid=6195;start=0#57545 date=1035575291]<br>Rod, know any dates for those early 98.5s and what was the reflash for? Mine has a sticker for a reflash or something. Will check this over the weekend and also look at engine plate to determine date of manufacture. Mine is getting over 17 mpg since I took my slide in camper off and lost my muffler. Could it be one of the ones you're talking about?<br>[/quote]<br><br>Unfortunately, I don't. The 2 trucks that I've experienced were February 1998 builds, I believe. The customers were both among the first to have 24 valve trucks in Saskatchewan. I'd track them down and ask them to check for me, but neither of them own the trucks anymore. One had so many other problems, he switched to a Duramax. The other is driving an 02 now.<br><br>As for the reflash, my guys at the Dodge dealer couldn't tell me what it was for. I don't know if they didn't want to tell me, or if they weren't privy to the info. I have heard several unconfirmed rumors that it is was something to do with emissions. Sorry I can't be much more help than that.<br><br>Rod
Re:Upgrades
[quote author=Push Rod link=board=7;threadid=6195;start=0#57974 date=1035728568]<br>...The 2 trucks that I've experienced were February 1998 builds, I believe...[/quote]<br><br>I may have to check in to this a little more since mine was built 2-5-1998. Below is a link to what mine was reflashed for. It basically says this:<br><br>Problem: <br>The engine control module (ECM) on 30,000 of the listed vehicles may cause the engine speed to increase unexpectedly if an erroneous crank position sensor signal is received.<br><br>Repair: <br>To correct this condition, the ECM software must be updated (reflashed). <br><br>The ECM software which is loaded during the recall procedure also includes any other ECM updates which may have been released (i.e. TSB's) between the date of manufacture and the issuance of the TIL CD update which was used.<br><br>Link to Recall #799<br><br>Not that I'm dissatisfied with my fuel mileage now, but 20-21 mpg would really be great if I could get that by adding an EZ.<br><br>CR
Re:Upgrades
I rather think it was this recall<br>It seems that they corrected timing (for NOx) and max. fueling ( for HC)<br><br>Maybe some Cummins dealer could reflash the ECM with some proper code ???<br>AlpineRAM
Re:Upgrades
I bet you're right on that Alpine. Mine was supposed to have this reflash as well, but hasn't. Guess I won't be registering it in CA, not that I'd want to. So much for the 4 mpg increase. But I'd rather have the mpg I get now than have the reflash done and the mpg go down. Guess I'll have to come up with some other excuse for getting an EZ. :
<br><br>CR
<br><br>CR
Re:Upgrades
The initial attempts at reflashes by DC were TERRIBLE.<br>They had someone probably guessing at what the soulitions were for some of the reflashes like what Alpine RAM has mentioned.<br><br>I had a 98 and it was a turd from the get go.<br>One of the very first in Canada and what a pc o crap.<br><br>Now I am getting 100 miles per gallon or better since the truck is in pieces until tormorrow.
TPilaske
Nov 19, 2002 02:00 AM
crossy
Nov 14, 2002 11:26 AM
