undercoating or paint?
Old Feb 24, 2016 | 06:28 PM
tvnoober's Avatar
10 Year Member
my trucks getting all the body work done here soon. and i want you guys opinion on if i should just use paint or should undercoat it. i have heard that undercoating is bad cause water gets behind it and stores back there. what do you guys think. good paint or undercoat. what did you use when you did your truck or would use.
Old Feb 24, 2016 | 06:33 PM
Undercoat it it an oil and power wash it and undercoat it again before the next salty winter is my call.
I use bar and chain oil with a little diesel fuel to thin it down if I want it to soak into the seams.
Old Feb 24, 2016 | 07:21 PM
tvnoober's Avatar
10 Year Member
i spray used motor oil under my trucks for winter to keep the salt away. the thing im trying to ask is. my trucks getting 100% redone the body the guy is gonna paint the frame and all. but when hes down there should i just let him paint under the cab or should i get him to undercoat it. under the cab it has surface rust and i want to touch everything all up make it look nice. but i heard bad things about undercoating
Old Feb 24, 2016 | 08:06 PM
SIXSLUG's Avatar
A good coat of paint is hard to beat, but it has to be prepped right, no oils or contamination and sanded everywhere for good tooth so the paint will adhere. Then go back to oiling it...
The undercoating stuff seems to never adhere to 100% of everywhere..
Honestly, I was going to take off the flaps and running boards when I bought my truck, but after seeing how well preserved the rockers and door bottoms were I left them on.
Old Feb 25, 2016 | 12:12 PM
City Rat's Avatar
POR 15 is your friend
Hi, while I'm a newbie to this forum I have been through restorations of off road and older cars before. you want the body guy to use POR 15 on the frame. It is a paint and it bonds to the metal and neutralizes rust. It is pretty much a standard in the frame off car restoration world. Stop Rust with POR-15® - We Know What Permanent Means!
Yes, I have used it myself in the restoration of a 1980 Toyota Landcruiser which saw 80% off road, 20% DD duty and may well use it on the '99 2500 4WD diesel I just picked up. Good luck.
Old Feb 26, 2016 | 01:51 PM
mopar24v's Avatar
I have used rustoleum undercoating on all my jeeps with great success. I did it myself. i love the stuff
Old Feb 28, 2016 | 08:59 AM
high bid's Avatar
Yep^^^^^ what he said. Por15!
jka
29
Dec 31, 2010 04:25 AM
Rammer64
Aug 11, 2004 11:34 AM
herb
Jul 1, 2004 09:43 PM
Thunderjet
Dec 16, 2003 02:29 PM
tarpilot
Aug 2, 2003 11:26 PM
