Twins at last
Old Dec 16, 2006 | 04:49 PM
n0ne's Avatar
Twins at last
So i got a set of ATS Compound Turbo's finally.. .i knew it was coming eventually.. and i must say .. i'm impressed with the quicker spool up and the much cooler EGT's... i used to be able to peg my 1600 degree pyro even with the water/meth on.. and now i can't even break 1300 degrees.. Its amazing..
Old Dec 16, 2006 | 05:11 PM
dieselfan's Avatar
did you use your HTT62/14 in the setup like planned?
Old Dec 16, 2006 | 11:14 PM
n0ne's Avatar
naw.. i wasnt able to use it.. i ended up going with their Aurora 2000.. it was just easier.. because their Aurora turbo's bolt together with a custom hotpipe between exhaust housings... kinda neat.. but yeah.. clamps won't work.. they made me a pretty good deal since i was there.. and didnt wanna send me home dissapointed..
Old Dec 17, 2006 | 07:39 AM
dieselfan's Avatar
that sucks kinda. glad you like them, now go get on the dyno and see how much difference they make. your probably ready for some bigger stix now, mach's 6 or 7's would be sweet with that setup.
Old Dec 17, 2006 | 08:30 AM
dieselrob's Avatar
How much boost are you making? Is your comp a drag or regular? I think im gonna order me a sps66 in the next to weeks. I need air bad.
Old Dec 17, 2006 | 10:58 AM
n0ne's Avatar
i just have a regular comp box... i really don't push any more boost atm... just alot cooler boost.. i hit 40 psi but i will be able to make that go up once i get bigger injectors.. but heck i'll take the same amount of boost at prolly 400 degrees cooler EGT's than more boost but still hot ..
Old Dec 17, 2006 | 12:02 PM
CTD2001's Avatar
Did you get your head redone?
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
82NDSNPR
Jan 27, 2009 10:46 AM
Stock 02
28
Sep 24, 2006 11:09 AM
