twins
twins
were is a good place to source parts to build a twin turbo kit i want to use my hx 35/40 hybrid for a top turbo but am unsure as to what to use as a bottom turbo
this will be a towing set up for the 500 hp range any info would be great guys
Originally Posted by Austin'sDodge
Rip at SourceAutomotive.com
I have a S400 on the bottom and like it alot. With a 35/40 on top you would have a very nice set of towing twins.
Paul
Originally Posted by paulb
X2, but it's SourceAutomotive.biz
Paul
Paul
Thanks a lot for the link... i saw it somewhen but forgot the site. im so thankful! to have found it again!
PDW sells them for $800
http://www.performancedieselwarehouse.com/1124703.html
city diesel sells s400 for 650. I've got a buddy that sell them for 600. With a 35/40 hybrid on the top it will spool better than stock. When I had a 35/14wg on top of the 3b I had boost at 1200RPM. It should spool pretty quick. The bottom turbo actually give the top turbo a little back pressure to help with spool up.
there aren't realy any blue prints. It's a cut and piece together, doesn't fit, cut some more, grind this, hammer on that deal. That is unless you buy a kit like RIPs and then its pretty much put it together and weld.
Originally Posted by 24Vford
...what about wastegates
Assume you already have a WG on your 35/40 turbo?
RJ
i am looking at purchasing a used twin turbo set-up from a cousins friend of mine. and it only comes with the one turbo and its a ht3b. how good of a turbo would this be with my stock turbo on my truck??? and which should i use on the top and which on the bottom?? or what should i change out???
thanks
thanks
thanks
thanks
