twin vp44s
Old Jan 5, 2007 | 12:52 PM
inline6power's Avatar
twin vp44s
would it be possible to make a twin vp44 setup like you common rail guys have the twin cp3 now, and i am just thinkin, if you had twin vp44s, you could have twin fueling boxes couldnt you? just a thought
Old Jan 5, 2007 | 12:57 PM
PourinDiesel's Avatar
Anything is possible.
You would only need one fueling box.
That VP44 is quite a capable pump even in stock form on the SO trucks.
Old Jan 5, 2007 | 01:11 PM
bnold's Avatar
Don't think there is room for another timing gear to run off of?? Sounds like it would be a massively huge mega project
Old Jan 5, 2007 | 01:12 PM
signature600's Avatar
Possible...Yes. Anything is possible with enough Cash!
The problem is, the VP44 is not as simple as the CP3 that the CR's use! The CP3 is just a pump, that's it, it doesn't do much "thinking" other than "how much do I pump" The injectors do all the hard "thinking"
The VP44 does it all, advance timing, pump, meter fueling, everything...the injectors are simple mechanical devices that pop when the pressure gets too high
I'm sure someone could do it, but you'd have to find a way to control the other pump. I'm not quite sure how the injectors would like two pumps either!
A Better way would be to find a way to make it bigger...kinda like a hot rod pump, only hotter!
Chris
Old Jan 5, 2007 | 02:46 PM
Andy505's Avatar
prolly could be done....would be a lot of fab involved though....would be interesting to see!
Old Jan 5, 2007 | 03:09 PM
yeah just throwing up an idea i mean right now i think just a stock SO pump is the best, and i have owned a HRVP to. i just wish there were ways to get more fuel out of it rather than going to HUGE injectors. the common rail guys can get close to 600 or 600 plus with just electronics. they dont need HUGE injectors to make the power. just wish us 2 gen guys could do that.
Old Jan 5, 2007 | 03:55 PM
jwb600's Avatar
SOUNDS LIKE TWIN TURDS THE VP 44 IS NOT THE BEST THEY HAVE MADE, NO MATCH FOR THE CP3
Old Jan 5, 2007 | 07:33 PM
Rods's Avatar
Wonder if u could mount it like the cp3s (on top) and use a y harness that tell it when to fire per cylinder as the bottom then tie yr lines together say run the top pump lines into the bottom then to the injctors , run the top pump with a pulley like the others too
Old Jan 5, 2007 | 10:41 PM
ratsun's Avatar
I agree
I didnt like the one I had let alone want a pair of them
Old Jan 5, 2007 | 11:33 PM
kelownadiesel's Avatar
I think if you were gona get that crazy one would be better off swapping over to a 7100 pump
Old Jan 6, 2007 | 12:40 AM
Tate's Avatar
Originally Posted by ratsun
I agree
Just think, when one dies, you still have another to get you home.
Old Jan 6, 2007 | 01:03 AM
Forrest Nearing's Avatar
P7100 4 LyFE!!!!!!
Old Jan 6, 2007 | 02:01 AM
TheBigNasty's Avatar
Yeah, when is the last time you have drained the rail on your P-pump? HA!
Old Jan 6, 2007 | 07:14 AM
Most people would never know, since we don't run FP gauges I would bet quite a few people don't know how low they're pulling FP at WOT!
Me included...for now
Chris
Old Jan 6, 2007 | 11:24 AM
As of last week I have my FP hooked up. As for pressure, I'm at 15 and won't go much below 10 at WOT. But I'm about to fix/mod the OFV and change my fuel filter that has been on there way too long.
