Twin turbos boost prob...
Old May 31, 2016 | 11:04 PM
micdazel's Avatar
Aright I list my mods first
Twin turbo set up 60mm over a s475
6x.018 stick hot rod pump
Fass 220 quadzilla 4K
Head studs ported polished heads
Colt stage 3 cam
So Idk if I am boosting my full amount of not but I only boost about 50lbs in 5th 57lbs in 6th I figured I would be more close to 70 idk what the problem is but I feel like should boost more and I ve checked for boost leaks and I don't have any. What do You guys think?
Old Jun 28, 2016 | 09:05 PM
johnny5.9's Avatar
How are your egt's? So long as they're being kept in check, your amount of boost is sufficient, so beyond that it's just a number.
Old Jun 29, 2016 | 09:25 AM
patdaly's Avatar
Also don't forget, the better flowing the head/cam combo, the lower the boost will be for a given HP level.
Boost is largely a measure of flow restriction.
Since you have a good cam/polished ports, I would think your boost levels would be lower than a typical stock twin configuration.
dditt0635004x4
13
Feb 7, 2007 12:36 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
1320
30
May 31, 2003 01:01 AM
danlit
Jan 16, 2003 09:29 AM
