turbo upgrades
Old Sep 26, 2004 | 06:56 PM
hotmopr's Avatar
turbo upgrades
I am getting some 370s and have been looking at HTTurbo compressor upgrade kit with the 60mm wheel and housing. Plus a 14 or 16 cm2 turbine housing. Has anyone done this to their turbo? How well does it work? Did you install it yourself? Any info would be appreciated...
Old Sep 26, 2004 | 07:32 PM
infidel's Avatar
I've done the HHT turbo upgrade on several trucks, easy to do and works great. Very straight forward job.
The HHT upgrade is quite a bit louder no matter what size housing is used.
Old Sep 26, 2004 | 10:22 PM
hotmopr's Avatar
What is required as far as machine work? Do you recommend the 14 or 16 with the 370s?
Old Sep 27, 2004 | 12:30 AM
Jambbii's Avatar
Very easy to do, just did mine last week. They require machine work if you want to use your existing compressor housing to fit the larger inducer wheel I believe. Make sure what turbo you have because I have a 95 and it ended up being a WH1C. I went with a 16cm2 housing. I love it right now without the 370s although I have the injectors sitting in my garage right now.
Old Sep 27, 2004 | 12:48 AM
hotmopr's Avatar
From what I have heard the machine work has to do with the center part of the turbo. The bearing support?? The upgrade comes with a new compressor housing. I just want to know what they do to the center?
Old Sep 27, 2004 | 02:17 PM
MLR1's Avatar
The compressor wheel is slightly recessed in the end of the bearing cartridge. So when you upgrade to a larger wheel you need to machine the recess to accommodate the new wheel.
HTH.
Max
Old Sep 28, 2004 | 11:59 AM
vssman's Avatar
Stage 3 with a stock 12 housing gives me zero lag... I'm sure quite a bit of back pressure but still zero lag. I bet the stage 3 with a wastegated 14 that has been polished would be the best of both worlds.
mcevins
Jan 3, 2005 03:23 PM
BRUTIS 600
Oct 12, 2004 12:01 PM
CrazyKracka
Aug 9, 2004 10:16 PM
nick_domingo
Jun 8, 2004 05:02 PM
