Turbo Question
Old Feb 28, 2005 | 11:29 AM
2whistlers's Avatar
Turbo Question
I have access to an HX40, H2E, HX55, HX60, and possibly an S-300. I know more info is needed, but that's where I was wanting help. What size housings? Which charger? Can I spool these with ease? My truck is my daily driver so I need reliability as well as easy spool and good performance. Any help or info would be appreciated. Oh, and the BD-7's I've got listed as on my truck.... Should I stay with them or trade for EDM Mach 4's? I've got that option as well. thanks
Sale items should be placed in the classified section, not the forums.
Old Feb 28, 2005 | 11:41 AM
signature600's Avatar
HX40-HX60 should work good as twins. The H2e and HX55's would be large...but laggy if not modified...but would work as singles.
The S-300 could work with the HX60 as a twins setup, depending on housings.
Now as to what housings you need, Uh. Don't have any idea!
Chris
Old Feb 28, 2005 | 12:25 PM
RowJ's Avatar
I assume your still running a stock turbo, since you don't list another...and as such are living with big EGT problems. If so, an HX-40 would make a big difference for you and still spool well. Anything bigger and I would guess you would not like the lag.
Mach 4's are, in my opinion the coolest running (egt's), big injectors on the market....and an honest 150 hp.
With the TST Comp PM3, and big injectors, I don't think any single turbo will stop you from being able to hit 1500 degrees in a heartbeat...other than maybe the HX55 or a Full B-1.
If not too concerned with EGT's...an HX40 with 16 cm housing for spool up; or the 18 cm housing if you do want lower EGT's.
RJ
Old Feb 28, 2005 | 06:40 PM
59Dsul's Avatar
I'd take a good look at the s-300. If it's spec'd right, you've got yourself a full B1 and saved about $1500.
andy
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
