HELP! ashtray light wire for gauge????
Ok, I'm at the last step, the lighting. Which wire on the ashtray light? Black/orange or brown/green? Those are the colors on the pigtail. The colors leading into the connector are orange/black and orange.
Hello
I only have a manual for the 02, but it shows the black/orange for the lighting and black/red for the power. Test it I guess and see. I think you will get a more accurate reading if you bleed the line to the sender, but I doubt it is that terribly important. I hope someone who has a '99 can confirm the wiring for you.
mishkaya
mishkaya
Just got back from taking her for a run.
Fuel pressure: 12.5-13 at idle, 9 at WOT (2500rpms) ... broke the tires loose, that's a first
She drops to around 10 at normal acceleration.
Boost: 5-6 at normal acceleration, 18 at WOT
Do the numbers sound right?
Tapping for the EGT tomorrow, so I'll let you know how it goes.
Still stumped on that dimmer light
Oh, BTW, diesel is an excellent engine cleaner
. When bleeding the line, I left the hose in a Dr Pepper can and bumped the starter ... looked like Niagra Falls ... Stupid Andrew!
She drops to around 10 at normal acceleration.Boost: 5-6 at normal acceleration, 18 at WOT
Numbers seem fine to me. Just make sure fuel pressure never drops below say 5 and you should be plenty safe. Boost sounds right if you haven't changed the wastegate adjustment; it's set for 18 to 20. Sorry I couldn't be of more help on the wiring
mishkaya
mishkaya
That's what I love about this forum, when someone is looking for help, there's always someone who wants to throw in a negative statement.
How about some help! If you don't have something constructive to say, don't say anything.
does that ring a bell at all??? remember all the PM's I sent you????)..Thats what I love about this forum....people that ask for advice, and then they dont like the advice they get.....whatever...my opinion, FWIW
Dr. Evil, dont' get your knickers in a twist! The post pertains to looking for the appropriate wire, not that, in your opinion, I have purchased an inferior product. I bought the gauges because I liked the dual gauge feature and wanted a matched set. Unfortunately, the Westach line of fuel pressure gauges are only available in electrical. I asked opinions from those who own this gauge and have not yet found a problem.
Thanks for the advice, but, for now, I'm sticking with what I have ... shame on me if it doesn't work out.
Now, can you help me with the wire????
