turbo Q
Old Sep 27, 2010 | 08:32 AM
joebaker82's Avatar
turbo Q
when shifting My boost gauge doesn't give me a reading to I hit around 2k rpm. Than when I start getting boost on the gauge I take off. Driving around 60mph i also run at 0psi until i stump on it than i can get 32psi. It just seems strange that im running no boost at 60mph. Any thoughts?
Old Sep 27, 2010 | 08:34 AM
j-fox's Avatar
normal
Old Sep 27, 2010 | 10:08 PM
Midnite's Avatar
Depending on conditions I'll run between 0 and 10 psi at about 60. What's your EGT at 60 when you're showing no boost?
Old Oct 2, 2010 | 01:32 AM
KATOOM's Avatar
Boost is related to the amount of throttle your giving. Lite throttle conditions, like puttin down the main drag at 1200 RPM, will show zero boost.....but hit the throttle, the fuel rushes in the engine, the RPM's rise, and the boost increases. Also, at 60 mph you should be running around 5-7 psi of boost. If not then you may have a boost leak or your gauge is inaccurate.
Old Oct 2, 2010 | 06:34 PM
cmed250f's Avatar
go up a 8 percent grade at 60 youll get boost
Old Oct 4, 2010 | 10:42 AM
Midnite's Avatar
It would be nice for the original poster to say what his boost is cruising at 60 on level ground.
This could also be a leak in the air hose to the gauge, but it's tough to say without more information.
Old Oct 4, 2010 | 07:36 PM
BigGreen's Avatar
Mine is close about 5psi at 60 but remember if you have a 60 psi gauge it dosen't appear to move as much.
Old Oct 4, 2010 | 09:25 PM
turbodiesel101's Avatar
i have a 35 psi gauge and i read 4-5 psi rolling on flat ground at 60 but like stated above a high psi gauge will not show the small amounts of boost very well.
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
