Turbo psi vs head gasket
Old Oct 25, 2006 | 06:31 AM
Jetpilot's Avatar
There really isn't a magic number here..... We use 40# as a max on a stock head. We push that number up to 45#-50# when running studs. If you o-ring + studs 80# is no problem. All of this assumes the engine was completely warmed up prior to pushing the engine.
Problem here is that each truck is different. I have seen trucks blow HG at 30# on the stock setup yet others push 60#. The best we can do is take preventive steps.... Studs are a good start but o-rings are better.
Doug Smith
Old Oct 25, 2006 | 07:35 AM
RowJ's Avatar
Doug Smith
Great Point!
I think stock heads are kind of like stock auto trannys..... major variations from one to another. They all do the job at stock power levels, which is what they are designed for, but some heads come from the factory sealing better than others, due to variations in how flat/level they are when manufactured.
I lost mine at under 40 psi... but it was from a teen age type, 'high testosterone' moment ...... playing hard before the T-stat had opened and before the engine was fully warmed up. (Another great point made by Doug).
RJ
Old Oct 25, 2006 | 08:07 AM
adidasman23's Avatar
well thanks for all the input. the turbo works great and i guess i will be buying o-rings and studs.
Rob
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
jr22
May 22, 2007 11:49 PM
johnsjas
25
Nov 27, 2005 04:16 PM
CTD_Neil
24
Jul 27, 2005 10:12 AM
