Turbo psi vs head gasket
Old Oct 24, 2006 | 09:43 AM
adidasman23's Avatar
ok i finally broke down and ordered a HB2 turbo for my 2002. what psi should i run the turbo at that i won't blow a head gasket. are should i say what psi do the head gaskets usually blow at. i am just wanting to know so i don't mess up my truck. should i buy bigger better head bolts.
just wanting everyone input for this.
Old Oct 24, 2006 | 09:48 AM
blackdiesel's Avatar
Registered
42-44 would be perfect. on the lower side, just to be safe
Old Oct 24, 2006 | 11:08 AM
getblown5.9's Avatar
depends on the turbo. the drive pressure is really what you need to look at.
i may be wrong here but you can be safer pushing 40psi on a bigger turbo with less restrictive turbine to keep drive pressure down, than running 40psi on a stocker because the drive pressure to make 40psi on an HX35 is much higher than a phat shaft 62 etc
someone please correct me if my info/thoughts are totally wrong!
Old Oct 24, 2006 | 11:48 AM
redstreak's Avatar
I'd keep it at or under 45 and you should be just fine.
Old Oct 24, 2006 | 12:08 PM
RowJ's Avatar
Adidasman23 - You don't mention turbine housing size... but either way I'll bet it comes wastegated at 40 psi. I would leave it there!
Difference in drive pressures between 40 & 45 psi can be great, and over 40 on most med sized single turbos is more expansion pressure from heat, rather than true compression boost pressure.
JMO - RJ
Old Oct 24, 2006 | 01:50 PM
Ken in AZ's Avatar
I would concur, my stock HX35 blew the stock headgasket at 42psi, while here I am on the marine HG at 47psi with no problems "yet" I plan on adding the 370s and pushing 50-52lbs on this B1....possibly adding a pressure gauge to the exhaust to measure drive pressure
Old Oct 24, 2006 | 01:54 PM
HOOKED's Avatar
My stock head gasket was pushed to the limit with a SP66 at 55-60PSI all the time never blew honestly i think this is a rare case.. But now its O-Ringed just to be safe...
Old Oct 24, 2006 | 02:43 PM
so what should i do about head gaskets. should i keep mine until or if it blows. if it does blow do i put studs on it and/or a better head gasket. where can you get a marine gasket at.
Old Oct 24, 2006 | 02:47 PM
id put studs in it now...that will help to keep a good clamp on it. if it still blows down the road then you only need a $200 modified 12v marine gasket from Performance Diesel Warehouse to get it back together rather then putting out all $600 in a hurry to get the truck back together with a new gasket AND studs
NoSeeUm's Avatar
Double....
Old Oct 24, 2006 | 02:49 PM
NoSeeUm's Avatar
I was pushing over 60 psi drive to make 35 psi boost at the compressor. How much over I'm not sure, the gauge only went to 60 psi.
Jim
Old Oct 24, 2006 | 03:51 PM
halerazor's Avatar
i was running 70psi on my sps62 while sled pulling and didn't blow the head but it sure made me nervous
Old Oct 24, 2006 | 11:21 PM
oestreich84's Avatar
I could be wrong but, I don't think you will be able to make enough boost with just a comp to have to worry about the headgasket. Leave it set at 40, and have fun
Old Oct 24, 2006 | 11:26 PM
i hope you wastegated it back because you have about 30psi of boost there that is only creating heat. 40psi on a 62mm is gonna pretty darn efficient where as 70 is way too high. unless you are referring to drive pressures being at 70psi then my statement doesnt apply.
i made the HP in my sig gated at 42psi on my 62mm B1
Old Oct 25, 2006 | 05:12 AM
halerazor's Avatar
look at the vid in my sig i was running 70# there also way over 1600* by the time i hit the 100ft mark. it was enough to to put 30ft on some of the toughest dmaxes around and take 1st place
