turbo info ?
hi
i have a 98 12 valve .auto trans
seams to have hi egt pulling at app35 mph up steep grades where i think i could use more boost at the lower speeds 3.55 gear ..
would installing a wicked wheel in the turbo help this ?
anyone ever used this and got more boost down low ?
no real prob at hiway speeds .
thank you !
thank you !
i have a 10 plate and messed with the afc some but i really dont know what i am doing .
get some dark exhaust under load and thought more low rpm pressure might lower egt ?
boost seams low at low speed towing long grades , higher speed seams fine have seen over 24 lb higher speed on lower grades ?
thank you !
thank you !
Have you checked for boost leaks?
Rips in the boots can cause this. Check the lower ones on a 2nd gen they like to rub the fender lip.
Also check if your intercooler is leaky.
All the clamps good and snug?
I have seen at low boost a small leak will lower the boost considerably, but at say 20 PSI - the small leak is not as noticeable as the percentage of air leaked is much smaller.
With a 180 HP pump with bumped timing, a "messed with AFC" in your words, and a #10 plate, I would expect to see more than 24 PSI. I would expect to see 30+.
no leaks last time i chegked , been a while .
rebuilt turbo app 30,000 miles
it will spool higher than 24 at higher rpm ,
my isue is to get higher psi at lower rpm when pulling steep grades at lower rpm to cool egt .
egt is easily reading 1200 pulling at 1600- 2000 rpm .
has no one on here tryed the wicked wheel in there turbo ?
thank you !
thank you !
Could you describe when and how this was done.
Pretty easy to check the lower boots for cuts, holes and tears, even by hand.
Another option is shift down a gear when the ETGs are getting too high.
Pulling big loads up steep grades at 1600 RPM is the perfect recipe for getting the ETGs high.
