turbo help
Old Jun 9, 2008 | 05:51 PM
rebel5422's Avatar
Question turbo help
i got this switzer turbo off my brother he has a 01 auto and i have a 96 stick he could push 55psi out of it some one has plugged the boost elbow on it i can only get 30 or 31 out of it my question is there is supposed to be a ling btween the boost elbow and the nipple on the wastgate
on my 12valve there is no nipple on the turbo just one at the afc housing
i connected the line that goes from the stock turbos wastegate to the afc housing to the aftermarket turbos wastegate. is this correct or do i need to run a new hose from the aftermarket turbos boost elbow to the wastegate and close off the line comming from the afc housing? or do i connect the boost elbow to the wastegate and "T" into the afc line im kinda lost turbo is sluggish at the bottom and would expect much more than 30psi considering my stock one pushed 45psi any help would be apprieciated please help my truck feels considerably slower now than with the stock turbo
thanks
Old Jun 9, 2008 | 06:04 PM
aksparkey01's Avatar
should be 1 line from the elbow on the turbo to the wastegate. then 1 line from the manifold to the afc housing. you might have a leaking hose or clamp that didnt get tight when you switched turbos. what are your egts.
Old Jun 9, 2008 | 06:12 PM
rebel5422's Avatar
the line that goes to the afc it the one that was connected on the wastegate of the stock turbo.
so i should put the line from the boost elbow to the wastgate on and run a new line from the intake manifold to the afc housing and loose the original afc housing tube? the turbo came off a 24valve and is now on a 12valve if this helps.
also i smoke on the bottom more than i did with the stock one and it cleans up after id say 2000 rpms also i dont have a gsk kit in my truck soon though
thanks
Old Jun 9, 2008 | 08:33 PM
rebel5422's Avatar
my egts are deceptive cause i goofed when i installed the pyro i put it in the middle of the exhaust maniforld instead of to the side a little so it dont climb and lower instantly at 70 it is about 600-800 or so
Old Jun 14, 2008 | 11:41 AM
rebel5422's Avatar
got the plumbing worked out today no oil leaks no boost leaks. hits 35psi max and egts at wot are about 1200 at 100mph i guess the best solutions for me are more fuel and a wider rpm range cant wait for that 4k kit thanks for yalls help
CumminsRedneck
Jul 6, 2013 03:20 PM
Ada381
Feb 10, 2008 07:58 AM
smalltownTPull
Aug 26, 2004 10:55 PM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
