Turbo choice help
Turbo choice help
I am planning on installing a set of 100hp injectors soon and replacing the stock turbo at the same time. Anyone have any suggestions as to which turbo is the best? I am also looking for opinions on a controller...Edge or what? Thanks everyone..MURF
Welcome to the DTR.... as a poster
Need info. You don't list type tranny, which makes a difference in turbo size and importance of spool up! Also need to give best guess on where your headed, hp-wise.
Just one small suggestion. Do one at a time. Only way to evaluate results on mods is change one thing and drive it for a while .... just a week or two is enough if you drive it everyday.
RJ
RJ
sorry guys
Newbie here..sorry for the lack of info.
2001 quad cab.
automatic with 3.55 gearing.
5" mbrp exhuast
vp44 lightning pump
k&n fip kit
FASS 95 kit...
Looking for ground pounding hp and torque to drive everday. Not looking for a pulling rig, just a good hp runner. Thanks again guys and glad to be part of the community. GOD bless the USA.
2001 quad cab.
5" mbrp exhuast
vp44 lightning pump
k&n fip kit
FASS 95 kit...
Sounds like 500+/- hp. Assuming you have the auto tranny upgrade handled, your in a compromise situation.... needing to trade off.... fast spool up vs low EGT's. This is trickier with an automatic. I might suggest a PS 64/12... but talk to mfg for recommendations!
Other than twins... I believe the best after market turbos are the brand I mentioned about.... found HERE
JMO.
RJ
JMO.
RJ
RichN
Feb 20, 2011 08:40 PM
smokinram99
May 18, 2008 11:45 AM
justagoodolboy
Jan 25, 2007 04:40 PM
