Turbo from 3rd gen fit on 2nd gen?
Old Jul 16, 2007 | 02:39 PM
sledneck1's Avatar
I have seen a few turbos from 03 and 04 3rd gen trucks for sale for decent prices, is there any reason not to use them for an hy-35 replacement?
Old Jul 16, 2007 | 02:48 PM
BBA's Avatar
BBA
I will tell you yes and no i have a buddy with a 01 and his turbo went and and well he ended up finding a super phat 62 pretty cheap and he did it himself it look him a few days to make everythin finally fit up right and be "right" for his truck. But hey it runs good!
Old Jul 16, 2007 | 02:51 PM
farmboykjb5.9's Avatar
I was wondering the same thing cause my girlfriend has a 02 and i have a 05 and i was wondering if mine would fit on her 02
Old Jul 16, 2007 | 06:32 PM
sledneck1's Avatar
i meant the stock turbo just because you get get one for like 250-450 rather than spending miniumum 1200 for anything else and i thought it might be a little better than an hx-35?
Old Jul 16, 2007 | 08:48 PM
Stamey's Avatar
Only problem is those newer turbos are choked off more than your stocker, 9cm vs your 12cm. You'll have great spool up but the top end will suffer.
Perhaps you could swap the exhaust housings, but I do not know if that's possible.
Chris
Old Jul 19, 2007 | 08:48 AM
sledneck1's Avatar
Chris
Well my HY-35 is 9cm so this means the 3rd gen turbos are the same? I'm suprised nobody has tired this.
Old Jul 19, 2007 | 08:59 AM
gman07's Avatar
I don't know the specs for sure on the 03-04 turbos (except they have a 9cm housing), but I don't think they're much of a step up from the HY-35. The 05's I know have 62mm compressors, but they too have the small 9cm housing. PourinDiesel could probably give compressor specs for the 03-04's.
Old Jul 19, 2007 | 09:25 AM
rollincoal01's Avatar
They will bolt up, if you use a 3rd gen manifold, coolant & oil lines also.
Later,
Tommy
00 5.9 ctd
Feb 11, 2007 10:50 PM
GR40RCapri
Nov 29, 2006 10:14 PM
wcbcruzer
Sep 7, 2006 11:01 PM
turbo dreams
Aug 23, 2006 06:06 PM
Marine
Jul 15, 2006 04:36 PM
