turbo
Old 02-15-2007, 09:01 PM
01smokin's Avatar
turbo
what has aney one heard about the htb2 sled puller 66. is it comparable to the II66 or the silver bullet, what about the high tech 71 prostreet66 thanks
Old 02-15-2007, 11:22 PM
dieselrob's Avatar
https://www.dieseltruckresource.com/...d.php?t=134618
This should explain enough i think.
Old 02-16-2007, 01:37 AM
Ph4tty's Avatar
The sled puller 66 is comparable to the phat shaft 66.
The prostreet 66 is comparable to the super phatshaft 66.
I don't beleive HTT has anything comparable to the silver bullet line.
Old 02-16-2007, 05:10 PM
01smokin's Avatar
what do u think would work good with 200hp injectors, edge w/attitude, and smarty soon to come
Old 02-16-2007, 05:15 PM
dieselfan's Avatar
the one you can get the best deal on. they are all good turbos.
Old 02-16-2007, 05:27 PM
Registered
blackdiesel's Avatar
the ideal stack would be a tst pm3 comp/smarty, some mach 6's, a SO vp and a silverbullet.
i know thats not the question, but i have a feeling that you want max hp and ^^ is how you get it
Old 02-16-2007, 05:37 PM
01smokin's Avatar
isthe tst that much better than the edge for hp and why. and what do u mean by so vp
Old 02-16-2007, 05:47 PM
Registered
so vp means standard out put. you have the high out put pump. The SO pump will flow more on the top end than the HO pump will.
and yes, the tst pm3 comp is better than the stock juice w/a. thats not really even comparable though.....
the tst dosnt have timing so you can run the timing of the smarty instead of the timing of the comp.
now you could take your juice and run it in ez mode and stack a tst with that. ive herd that it nets a higher hp raiting than the tst smarty stack....
Old 02-16-2007, 05:49 PM
01smokin's Avatar
and do w/o the smarty
Old 02-16-2007, 05:50 PM
Registered
yeah, no need for the smarty if you stack the tst and the edge
Old 02-16-2007, 05:52 PM
01smokin's Avatar
w that thoe u wont have as many settings and as much adj abillity
Old 02-16-2007, 05:54 PM
Registered
huh? might try proof reading your posts before you acually post them because THAT DONT MAKE NO FRIGGEN SENSE!!
sorry, i didnt mean to raise my voice....
Old 02-16-2007, 05:56 PM
01smokin's Avatar
sry. if u did that you would not have as much adjustibality would u
Old 02-16-2007, 05:58 PM
Registered
trust me, you will run it on or off. been there done that. the different levels are pointless IMO.
and its very rare if you put the smarty on a different level. i always had it set on nine and the tst was always on nine and i had it were i could switch it on or off
Old 02-16-2007, 06:00 PM
01smokin's Avatar
that makes sence. so the ez and smarty on level nine are pretymuch the same
Quick Reply: turbo
