Tst
Old Oct 7, 2006 | 01:58 PM
jhood12's Avatar
Tst
Ok has anyone else had any trouble with connections with their TST box....I cannot get the scotch lock to hold for anything....It worked for a bit now nothing again and the scotch lock is broke...is there any other way to do this....Also has anyone else had their EGT Gauge read OPEN.....It will work for about 2 min then it just says OPEN....and when its reading its not even close to being right......Im about to the point to buying the pillar gauges and taking my truck to TST and having them do everything....
Old Oct 7, 2006 | 05:21 PM
blackdiesel's Avatar
Registered
throw the scotch lock away. They have now replaced them with some doodad that i was quite impressed with. It made the install about a 15 minute job. This included tapping the pump wire and an ignition hot wire under the hood.
I dunno what they are called, but it makes life a whole lot easier.
let me try to find the tst instructions, then ill get back with you.
Old Oct 7, 2006 | 05:38 PM
Registered
posi-locks maybe?
Old Oct 7, 2006 | 06:15 PM
jhood12's Avatar
ok im gonna have to figure out something cause this isnt working at all....I bought the box off of someone else so I didnt get the connectors TST sends out with the box.....
Old Oct 7, 2006 | 09:44 PM
Charlie8301's Avatar
"Posi-Tap" You can get them at wallmart, much better then Scotch locks. or you could get a pump cover
Randy
Old Oct 7, 2006 | 10:45 PM
Tiger Rag's Avatar
Posi-tap. O'reilly's carries them here locally.
Old Oct 7, 2006 | 11:01 PM
Registered
heh, i was close!
They are bout the best thing out there for splicing wires (that ive found)
i was dreading tapping the wire on my vp but when i seen the "posi-loks" it made the whole process very easy.
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
