Truck still acting up
Old Aug 3, 2004 | 09:30 PM
OldSmokey's Avatar
My 2000 is having some probablems when I run the comp on level 4 or 5. It works great on the other 3 settings . The probablem that I'm having is it cuts out on wot runs, and completley falls out at 90 mph on 5 and 95 on level 4. Also it only seems to do it with the throttle all the way to the floor. I checked all the connections and I noticed that the little purple boot on the map sensor is missing. I have been running for quite some time with some codes 0251 and 0252 both injection pump codes. (Hopefully they came from the loose pump wire). Oh my fuel pressure is always at least 8 psi. I am all out of ideas. I think that i will send my comp in to edge if no one has any other ideas. THanks Joel
Old Aug 3, 2004 | 11:09 PM
BigBlue's Avatar
Try clearing the codes and see if they come back. I'd definately send the box to edge.
zookeeper
Aug 13, 2011 12:08 PM
abc4yew
Mar 29, 2008 08:37 AM
MoreSmoke
Feb 22, 2004 08:50 AM
hellotbone
Jan 16, 2004 07:30 AM
AKDSLDOG
Dec 9, 2003 07:02 PM
