truck heats up good
Old Jun 30, 2005 | 03:17 PM
IntakeRacing's Avatar
truck heats up good
i have those grill inserts for summer and winter and now i don't run any of them cause my truck heats up like a ***** towing the car hauler. i don't feel like dumping a lot of money into fixing this. is there a cheap fix?
its the hills that kill me or if i put my foot into it. even without a load.. if i have my o/d off and trying to get up a crazy hill for a long time starts to heat up as well.. like i never have had it overheat but i've had it get **** close on my needle/.
Old Jun 30, 2005 | 03:40 PM
gunracer1's Avatar
pop your fan off, and pull your radiator, or just clean it from behind. the late 24v trucks oil bottle has a habit of coating the back of the radiator with a film of oil. and make sure your fan clutch works.
Old Jun 30, 2005 | 10:55 PM
Mopar1973man's Avatar
You need a puke bottle relocation kit....
This will cure a bunch of problems with crankcase vent / breather bottle on the front of the engine. You will no longer have the oil mess on the front of the gear case and it will keep the oil off the radiator...
Old Jun 30, 2005 | 11:59 PM
Haulin_in_Dixie's Avatar
Change your thermostat with a new 180 degree. Most important is changing it.
Old Jul 5, 2005 | 04:23 PM
kevinn's Avatar
Where can one find a 180 degree thermostat? I have also been told this isn't available for an '02.
DW Poyer
Jul 17, 2007 12:32 AM
risner
30
Oct 13, 2006 04:44 PM
Dodgezilla
Jan 17, 2006 12:05 PM
HOHN
Oct 14, 2005 07:31 PM
