transmission heat
Old Oct 3, 2007 | 05:34 PM
olddodgetruck's Avatar
transmission heat
my tranny is good when im moving. if i give it hell i can only get it up to like 200 degrees. but when im in traffic i can get it up to like 230 degrees. my tranny sensor is in the pressure line before the heat exchanger. and it is not slipping. will a cooler with a fan on it help
Old Oct 3, 2007 | 08:13 PM
heykw's Avatar
I have the same issue, I have been thinking of going to an electric fan
Old Oct 3, 2007 | 08:17 PM
1-2-3's Avatar
Just a plain ole guy
I beleive this is common. I've seen a minivan go way higher than that sitting still. The deal is the tranny has to slip everything to sit still so makes heat. A cooler fan certainly will not hurt, although those things pull alot of juice. Make sure you have enough extra power available for it.
Old Oct 3, 2007 | 08:20 PM
iker42's Avatar
if your gonna be sitting in traffic, shift into neutral to keep the gears free and the fluid cycling
Old Oct 3, 2007 | 08:47 PM
wcbcruzer's Avatar
Good advice, that's what I do if I'm sitting at a long red light or in heavy traffic.
Old Oct 4, 2007 | 08:38 AM
does anyone know if the plate style coolers work better then the tube style coolers
Old Oct 4, 2007 | 10:54 AM
iker42's Avatar
i've heard some negitive feedback on the aftermmarket trans coolers. something about the fulid trying to return back through the lines or what not, but dont quote me on that
give dave goerend a call = 563-778-2719
Old Oct 4, 2007 | 04:19 PM
wcbcruzer's Avatar
If you're talking about the stacked plate design then yes, it's more efficient than the older tube design. Don't know about the drainback issues. I wouldn't see a problem with running one though.
Old Oct 4, 2007 | 06:26 PM
Jordan5687's Avatar
Well, here's good timing for ya! I just installed a complete kit from bd-power.com Auxilary trany cooler. It lowers the trany temp about 75-100 degrees! It's complete, electric fan and all. I have a temp. sensor on it that turns it on once the fluid coming into the aux cooler is 180 degrees it'll turn the fan on, or wire it to the ignition and it'll run the whole time the truck is on. Great investment especially if any of you are running expensive fluid in there. Not that expensive either, check it out!
tswcoaltrain
Nov 12, 2019 09:11 PM
bkrukow
Apr 29, 2011 06:42 PM
kd460
May 24, 2007 04:21 AM
kennedy
May 12, 2006 11:19 PM
TurboTed
Jan 13, 2004 06:03 PM
