transmission Choice
Old Dec 14, 2006 | 05:35 AM
hillbillymudrun's Avatar
transmission Choice
I am going to replace my tranny in a few months and have heard of two main choices DTT and sun coast which is a better tranny or is there better ones. what about a tranny shop rebuilding one and making it stronger? I talked to a tranny shop and they said they could build one for 3000 that i would not be able to break (doubt that) DTT trannys get pretty expensive.
Old Dec 14, 2006 | 05:48 AM
n0ne's Avatar
you an auto or a manual?
Old Dec 14, 2006 | 05:50 AM
its got a auto
Old Dec 14, 2006 | 05:52 AM
n0ne's Avatar
well.. you can have your tranny shop install DTT/Suncoast/ATS/Goerend compenents.. if you wanna go that route.. a good Valve Body and Torque Converter should tide you over with what mods you have now.. and then when you get more and more.. just start adding billet .. (Flex plate, shafts).. I'd go with DTT i think they are pretty decent on prices..
Old Dec 14, 2006 | 05:56 AM
all and all i want to make 500hp 1000ft lbs i only want to do the tranny once so what components should i have installed i dont want to have it redone over and over if i decied to add some more power
Old Dec 14, 2006 | 05:57 AM
n0ne's Avatar
then you should go with at least all billet except maybe the intermediate and output shafts.. Gonna be pricey no matter what route you go.. just start calling around.. see what each company can do for you.
Old Dec 14, 2006 | 05:58 AM
pullmaxdude's Avatar
Exclamation
Keep looking, (Georand Bros), I have heard no bad about these guys, My next one will be theres, because I am sure my Suncoast is on its way south. You need to talk to different companys, get a feel for them and check there warranty. I was told a few months ago when my Suncoast converter was acting goofy that Suncoast only warrantys them for 12 months now. I was told when I bought it that it was covered for 3 years. Long story short version= took truck in they said they would change the converter this time since it was fifteen months since I bought the converter. But that is IT>> no more warranty.. which is just fine they put a low stall conveter in two months ago, and now with a trailer on it seems like the stall speed is around 2000 rpm....
Old Dec 14, 2006 | 06:04 AM
Thanks i guess i will just have to fork out some dough to get it done how much does a good tranny run normally with all billit
Old Dec 14, 2006 | 10:13 AM
bigdav160's Avatar
Check here just to get an idea of what the parts will cost:
http://www.transmissioncenter.net/dodge.htm
Old Dec 14, 2006 | 10:32 AM
RowJ's Avatar
Originally Posted by hillbillymudrun
all and all i want to make 500hp 1000ft lbs i only want to do the tranny once ...i dont want to have it redone over and over if i decied to add some more power
If you stop at 500 hp (a big if) and if you are not power braking (boosted launches) at the drag strip, I do not think you need billet shafts. This will save you two grand +/-.
Do a full rebuild from one of the big three and never look back. I'm at 90,000 on my DTT and love it. It has never so much as hiccupped once as I climbed to over 600 hp! And it was built to handle the 350-400 hp I said was all I planned on ever having
I did add billet shafts at 75,000 miles on the tranny and everything inside looked good to go another 200,000+ miles!
RJ
Old Dec 14, 2006 | 01:38 PM
y2kram's Avatar
Sun Coast Quality issues
I'm on my 3rd Sun Coast valve body since rebuilding the trans just under 3 yrs ago.
It's a lifted 4x4 w/35" tires, but i don't tow or haul any loads. I may do a little light off-roading once in a while, but nothing that would be hard on a trans!
They may have quality issues and don't know how to solve them and still remain competitive.
Old Dec 30, 2006 | 09:42 AM
Master Diver's Avatar
I had over 99k miles on my last DTT and I pulled hard and drive hard that truck was at 500hp and 1000fpt.
I am 99% sure I'll be with DTT on my '06 as well, NADP is getting some good press but when I talked to them they didn't have much confidence in thier east coast installers which means a lot to me! I don't want to have to worry about service/warranty issues that require me to get the truck/tranny 1000's of miles.
My 2 cents. Good Luck!
Old Dec 30, 2006 | 12:52 PM
BigBlue's Avatar
I've got about 10k on my DTT and it's held up great to 5psi launches and many many standing start WOT runs at 500+hp. It's definately been the best money I've ever spent.
Old Jan 8, 2007 | 07:39 PM
what components were put into your trannys i was looking on there website and there are alot of different choice but no explanation for each
Old Jan 8, 2007 | 11:46 PM
Fueling around's Avatar
Dunrite is just up the road from you in the Portland area. Tony has been building performance transmissions and converters for a long time.
South Bend Clutch
92
Jun 1, 2004 12:41 AM
kingofdodge7131
23
Jul 2, 2003 02:48 PM
DEC
Mar 7, 2003 06:02 PM
joel
33
Jan 5, 2003 10:34 PM
