trans temp sensor
trans temp sensor
im puttin gauges on my buddies 2000 cummins i got the boost and pyro done but im not to sure where the stock trans temp sensor is so i can swap them out and solder a 1000 resistor in place of it so where is the best place to put the sensor?
I never knew they had one stock. I always used a manifold made by Auto Meter that goes inline with the cooler line coming out of the converter so it is at the hottest point. They are not to high $ and it is the best way to do it. The sender in the pan is a bad way to go it tells you the temp after it comes out of the cooler and is back in the pan. Its too late then.
This is the best solution, because your gauge will read the hottest fluid temperatures in the transmission. This is the reason the earlier models 94-95 had the factory sender mounted on this hot cooler line.
Richpwb
Aug 15, 2008 08:01 PM
