trans temp gauge
trans temp gauge
well i got the gauges in and i know how to hook up the boost and pyro but how do you do it for the short sweep electric trans temp from autometer? do you drill into the pan or tap into the cooler lines? thanks
On your '95 it's easy, just trade your Autometer probe with the stock one.
Probe is on the driver's side about a foot forward of the tranny, only thing in the area with wires going to a pipe.
The AM probe is 1/8", stock is 3/8", you will need a 1/8"x3/8" bushing from the hardware store unless your AM kit came with one.
ATF will start pouring out when you remove the sensor, be ready to move fast and you won't lose enough fluid to worry about. Use no teflon tape on the threads, instead use Permatex #2.
You will also have to trick the truck's computer about the missing stock probe.
After you disconnect the stock probe and put it in your toolbox install a 1000 Ohm resistor (25¢ at Radio Shack) across the two connectors that used to go to the stock sensor.
thanks alot that clears it up now i got the install date for saturday morn. and after i call the co. that the guy said he had an aftermarket trans in it (have them pull up hist. with vin) and figure out if there has been any work to it decide to grind a 10 plate or 100 i hope its aftermarket though i really want the 100 now and not wait 1-2 years for the 5spd. swap
1985cucv
Feb 18, 2010 02:03 PM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
