Tranny lines
In the above picture, the threaded port, to the right of the wrench, is the outlet that goes from the tranny, to the heat exchanger under the turbo. Follow the lines, should be able to figure thr rest out. There is another cooler up front. 2 of the steel lines are attached to rubber lines that go to it.
I added a stacked plate design B&M super cooler in series with the stock ambient cooler up front. To hook it up I just hi-jacked one of the lines where they go from steel to rubber up in the front left hand corner of the truck.
Make sure you get a cooler with 1/2' NPT fittings, this ain't no sissy truck, it sporting 1/2" tranny lines. If you use a cooler with smaller diameter connections , you may be doing more harm than good.
D384D
14
Oct 26, 2010 10:23 AM
J BODY
Feb 6, 2004 02:29 AM
