track bar movement
Old Jun 1, 2009 | 09:22 PM
drivesmopars's Avatar
track bar movement
iam trying to find my problem with the steering wheh i go dwn the road i can move the sreering wheel back each way a 1/8 turn i seem always to have to do this its a 9712v 4x4 dually 140k miles all stock
my track bar at the frame end only moves at the most 1/8 inch
when i trurn the steering wheel back and forth without the motor going
is that normal movement? i cant believe thats the problem
all t rods did not move
how do i adjust the steering box??
thanks in advance
Old Jun 1, 2009 | 11:01 PM
Lil Dog's Avatar
Only moves 1/8"?? That's a fair bit of play IMHO... Any movement there makes the steering wheel sloppy.
Old Jun 2, 2009 | 01:54 AM
Ed ke6bnl's Avatar
with the doug thuren track bar it allows about 1/32in. and the frame bushing is set to a torque of 130 ft lbs. solved my problem ED
Old Jun 2, 2009 | 12:34 PM
seahawkdodge's Avatar
I went with the DThuren track bar myself. I'm glad I did. I went through two Napa "lifetime warrantied" track bar replacements in two years. I was tired of replacing them.
The Thuren unit has lasted 3 years so far, no complaints except the adjuster should be more accessable. I hate having to remove the axle end to adjust it. Once it's set though, it's set...
Old Jun 4, 2009 | 10:24 PM
If I Add A 2'' Frt Leteling Kit Do I Need The Adjutable Bar Reto Fit 3 Rd Gen To A 2nd Gen
Old Jun 5, 2009 | 08:25 AM
nickg's Avatar
I added a Carli suspension springs approx 2.75inch higher than stock, I already had an adjustable bar, it allowed me to pull the axel back under the truck, they claim it will work fine without an adjustable bar but the axel will be "off centered"
Old Jun 5, 2009 | 07:27 PM
Dave2001's Avatar
Any movement in the track bar is not good. I put a Luke's Link on mine, about $60. Been on there about a year with no problems. Fixing your track bar will probably cure the slop you have at the steering wheel end. The guy at the alignment shop I take my vehicles to, rebuilds the track bars using Luke's Link. He gives them a lifetime warranty. The only problem I had was that I did not tighten the nut enough. Once he adjusted the nut, my steering has been like new. The more expensive options work too.
Old Jun 6, 2009 | 12:43 PM
Beast2B's Avatar
some deflection in the steering box and sector shaft can compound the 'loose' feel. check out the dss steering stabilizers, they help firm up the steering.
BTW, I love my Thuren Fab track bar, too!
freeloader
Aug 5, 2012 07:52 PM
89dieselkong
Mar 13, 2012 09:29 PM
03CTDCO
Jan 14, 2011 10:38 AM
CTD2001
Aug 22, 2009 10:03 PM
kwillis-a
Jan 25, 2007 09:10 PM
