Torque Converters.
Old Feb 23, 2007 | 11:22 AM
99dodgediesel02's Avatar
Torque Converters.
A transmission shop is rebuilding a transmission for me.
They are putting in a Precision Heavy Duty Low Stall torque converter. It only has one lock up clutch plate, but Precision seemed to think it would meet my needs for what i do.
I have an Edge Juice module on my truck. I usually only drive it in the 3rd power setting.
Has anyone ever had any experience with these converters? Are they good?
Also they are putting in a Transgo Shift Kit.
99 Dodge Diesel 2500 Series auto trans /w/ Edge Juice/Attitude
Old Feb 23, 2007 | 02:45 PM
redpoint5's Avatar
I'm sorry I don't have any info for you, but I have a question; how much are the parts you are getting installed and how much for the total rebuild? I'm in the same boat getting a rebuild and just want to know what I can expect to spend. My local tranny guy quoted me at $2,800 total for a tranny rebuild with shift kit and heavy duty low stall torque converter.
Old Feb 23, 2007 | 05:24 PM
scottsjeeprolet's Avatar
If the TC doesn't have the billet front cover don't get it. the stock ones are weak and flex where the tabs are welded to them.
Do a search on Torque Converters there's lots of reading on them.
I have the TCI Maximizer from Jegs and it is working great, it has the billlet front cover, TCI has been building TC's & Trans for race cars for ever so they must know what they are doing.
Old Feb 24, 2007 | 06:58 AM
j-fox's Avatar
There are many guys running single disc clutch converters without the billet covers, with success. It is about experience!!! and Knowledge.
Many drag racers find that TCI is a poor choice, unless the converter is made for their specific combination.
I had a TCI in one of my Dodges behind a Cummins and it failed. Customer service was NO help. It cost me quite a bit to get my truck running again.
Be careful.
Old Feb 24, 2007 | 08:37 AM
JD730's Avatar
Becareful with statements like that, race car/gas engine transmissions and Dodge cummins aren't even close enough to use the apples vs oranges analogy.
I had a local shop rebuild mine with a billet single, shift kit, etc... Make the long story short the torque converter did not stall low enough for me, was only making 280/760 and I couldn't keep the converter from slipping in lockup. Had other stupid problems that really shouldn't have happened. I wound up fixing it with Goerend parts, triple disc converter with a valve body/billet front lever and I'm holding 350/760 now.
Hey 99dodgediesel02,
At least they are telling you what converter they are going to use, the shop I dealt with wouldn't tell me. I will give them credit, they gave me a brand new converter in exchange for my old one after the warranty was up, but I still don't know who's it is.
Old Feb 24, 2007 | 10:09 AM
Wink
Say what you want, sure i would have loved to get a triple disk from one of the big boys, DTT, Goernds or other but the $1K difference in price was my wallets deciding factor. I run the crap out of my truck on 5x5 in a DRW and hasn't slipped yet, i even ran a Smarty stacked on 8 and no slip just scared the crap out of me with all the crazy power. I'm sure the BD valve body helps a lot too.
What it all comes down to is what you can afford. When i step up into the High Horsepower i will of course get a new trans to match, but for now the TCI works great.
I don't want to start a trans war but i don't buy into all the hype that unless they are a diesel only trans builder they don't know what they are doing. The TCI has the billet cover and is built for a diesel not a gas engine.
Old Feb 24, 2007 | 10:13 AM
1workinman's Avatar
single disc converter
Be careful.
I believe that I read that the single disc converter with the non billet cover was welded and remachined to add some strength to the cover.
Old Feb 24, 2007 | 10:56 AM
J BODY's Avatar
.....I'd say going with TCI would be a crapshoot at best, but glad it worked out for you......I saw thier add for a converter but seeing some of their other product in the racing world I chose to skip them......and "assuming" since you are speaking of the great savings you had, you most likely chose the tci-142260 which lists on TCI's web site for $567.00, but can be had through vendors such as Jegs, Summit, for $379.00 which isn't much of a comparison to the other vendors you mentioned "triple disc" converters, matter of fact, TCI lists a 142263 triple disc converter for $1368.00 which would be more of an "apples to apples" comparison to the "big boys" you mentioned. Did you price a single disc through DTT or Goerend? Before you go touting your $1000 dollar savings, get a fair comparison.
.....that said I chose to call Dave after a few conversations with member McMopars here. He, like myself, can build a trans, but needed some "tips" on where to make it stronger. Dave was very upfront about what I needed for a trans and actually was steering me towards a single disc for my light mods and towing power application. I only went with the triple as it would give me room to grow in case I increased the engine power. True, I may have payed more, but I KNOW where to call him and will know WHO I'm talking too when/if I need any help. Try that with TCI.
Old Feb 24, 2007 | 12:40 PM
Ok Fellas lets stay on the topic of the original post!!
I just offered my advice on what i have and works for me. Read my original post and see where I got it. No need to brand bash here take it somewhere else.
99dodgediesel your gonna have to do some research on this one seeing that it is such a touchy subject.
good luck
scotte
I'm gonna go drink a beer and kick the cat.
Old Feb 24, 2007 | 01:38 PM
Fueling around's Avatar
If you're talking Precision Industries, they made the parts in my TC. PI supplies machined (billet) components to many builders.
Old Feb 24, 2007 | 03:34 PM
gwhammy's Avatar
I had a single disk and it worked good up to around 400 hp. I slipped it once and got out of it. I have two four disk convertors alike in two different trucks, one the 02 with hybrid turbo. The other one is in the 97 with twins and some fuel going to it. The one in the 02 seems real tight even under full power. The 97 starts getting loose with 65 lbs. of boost pushing it.
One convertor is not a fitall for all trucks, my 97 needs alot tighter convertor to hold the extra torque the truck makes. I'm real happy with the 02, it pulls hard for what it is.
I wouldn't be afraid of a single but if the itch starts creeping up on you it's some money and time down the drain to switch to a multidisk.
Old Feb 24, 2007 | 07:11 PM
J BODY's Avatar
good luck
scotte
...but stating you "saved $1000" was far enough out in left field for me to cry foul!
Whoever ends up providing you parts or building your trans 99dodgediesel, just be up front with them on how you are going to use the truck. Converters will be different from a "tow" to "go" set up. I simply wanted a set up that would pull my toys and that's what I built around.
Old Feb 24, 2007 | 07:40 PM
trod77's Avatar
I recently got a quote from my local transmission guy for a rebuild of my transmission. He said that the Precision heavy duty is the torque converter he is going to use. After you get yours back and drive it a little while could you give me some feedback on if you like it or not? He seems pretty confident in the product, but i would like some real world facts.
Thanks!
Old Feb 24, 2007 | 07:54 PM
redpoint5's Avatar
I would like some real world pricing too. Need to know what is a reasonable build cost. Unlike some people on this forums, I like to know I'm getting the best bang for my buck.
Old Feb 24, 2007 | 08:00 PM
trod77's Avatar
I was quoted $1800.00 on mine.
