Took the dually to the dyno
Old May 2, 2006 | 03:33 PM
v8440's Avatar
Hi all,
Some of you may have been following my thread about what turbo I should buy to replace the stocker. Well, I took the truck to the dyno today, partly to baseline it with the stock turbo. I sprayed the nitrous, and on the last (and best) pull, I removed the BHAF. It made 417 hp and 920 ft/lbs. I felt like that's pretty reasonable for having a stock turbo corking it up. Without the nitrous, it made 340 hp and 670 ft/lbs. The non-nitrous pull was the first, and I don't think the truck was really warmed up enough. I beat the previous torque record on that dyno by something around 250 ft/lbs. It was 600-something ft/lbs before, I think set by a car. I'll be going back shortly once I get my new turbo installed. I'm hoping to peg the torque on the dyno-it reads to either 1000 ft/lb or 1200 ft/lb-they can't remember.
Old May 3, 2006 | 09:07 AM
Eskimo's Avatar
That's a great gain from the n2o! What size pill were you running?
(Dang you Porterfield!!)
Old May 3, 2006 | 10:16 AM
v8440's Avatar
It's a #82. That size was carefully and scientically arrived at by going up in size until it "felt right."
Old May 3, 2006 | 11:10 AM
CTD_Neil's Avatar
Good job on the dyno runs. Maybe NOS would get me to 500hp? Hmmmmm, Or just blow the head gasket.
Old May 3, 2006 | 11:21 AM
mcoleman's Avatar
I think he probably saw greater gains than normal with the nitrous due to the stock charger and the heavy fuel. You might not see that much of a gain with a bigger charger.
Old May 3, 2006 | 11:26 AM
v8440's Avatar
Sure I would. MORE FUEL!!!!
Seriously though, I think you're right about the gains being large because of the extra fuel. I think you can imagine just how big the smoke cloud is with my setup and no nitrous. My friends don't really believe I can make traffic behind me COMPLETELY disappear until they witness it.
Old May 3, 2006 | 11:34 AM
mcoleman's Avatar
I do. I've been there when trying to run a catcher ecm with a heavy fueled truck in high humidity. Funniest thing you will ever see is people driving around the smoke like might get on there car.
Old May 3, 2006 | 12:41 PM
WideOpenThrottl's Avatar
You notice a decent reduction in EGT's with the nitrous flowing?
Tim.
Old May 3, 2006 | 12:48 PM
v8440's Avatar
Yeah, pretty good reduction. I don't know how much, because the gauge only goes to 1500 degrees. I'll put it this way: without it, I was not able to run an 1/8th mile pass before pegging the gauge. With it, I was able to complete a 1/4 mile pass just after it pegged it.
BRUISER
Feb 20, 2007 08:03 AM
j
14
Dec 26, 2002 03:38 PM
Alan_Reagan
Dec 24, 2002 09:38 AM
Dec 6, 2002 09:54 AM
rc
Oct 11, 2002 05:17 AM
