timing
Use a allen key in-between the valve and rocker bring it up on compression untill u touch the valve with the piston make a mark on the balancer, take the allen key out roll the engine past TDC put the allen key back in the same valve/rocker u had it in before roll the engine backwards untill you tap the valve again make a mark, take the allen key out find the center point of the two marks on your balancer and tada you have TDC.
Brandon
Brandon
Brandon
Brandon
Brandon
Brandon
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
