timing
Assuming you're running a 215 pump you should be @ 13.5 degrees.
http://dodgeram.org/tech/dsl/FAQ/timing.htm
I assume you're running stock injectors, stock head gasket and stock studs? As you bump timing you increase cylinder pressures, but you do decrease your EGTs. If you're basically stock I'd get nervous after 16 degrees or so.
you should be fine with 16, i jus went to advance mine this week (thinking it was at stock timing) and it was at 19.5, so i backed it down to 16.5, wouldnt go much higher than that on a stock head and headgasket
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
