Time for a Cam
Old Aug 8, 2003 | 06:42 AM
hellotbone's Avatar
Time for a Cam
Im set on getting a cam and from a very good friends recommendations I am going with a DD now how hard is the installation anyone have a walk through or any destructions?
Old Aug 8, 2003 | 08:05 AM
sherod's Avatar
Re:Time for a Cam
Jamie, Can't help with the cam, but the first thought I had when I read your post was that the only thing original on your truck has got to be the hood emblem.LOL
Ed
Old Aug 8, 2003 | 09:31 AM
StakeMan's Avatar
Re:Time for a Cam
I was thinking that Jamie must have a good job and be single.
Old Aug 8, 2003 | 09:41 AM
hellotbone's Avatar
Re:Time for a Cam
Not single but a good job 2 actully.
Old Aug 8, 2003 | 09:46 AM
Don M's Avatar
DTR Advertiser
Re:Time for a Cam
The cam is no easy task. I guess it is the single toughest upgrade you can do. No real HP gains up top, but the power will come on faster.
IMO I would have it done at Cummins or a good Cummins familiar mech. You need few specialized tools to make it happen. Lots of goodies have to come out of the way as well.
Radiator, AC condensor ( you may be able to lay it over and not disconnect it or open the system) the front cover, the rocker arms, push tubes, tappets ( with a special tool) and the old cam.
Not really for the faint of heart or first time mech. Cummins sells the tappet install and removal tool as well.
Don~
Old Aug 8, 2003 | 11:23 AM
hellotbone's Avatar
Re:Time for a Cam
So Don you want to make the trip up? ;D
Old Aug 8, 2003 | 11:28 AM
Don M's Avatar
DTR Advertiser
Re:Time for a Cam
I would do nearly anything to get out of this heat ( 109 degree F. yesterday )
Too bad you dot live arond the corner or me closer to you... better yet.
Don~
Old Aug 8, 2003 | 12:35 PM
hellotbone's Avatar
Re:Time for a Cam
Probably better where you are I would be much more indebt if you lived near by!
Old Aug 8, 2003 | 02:02 PM
banshee's Avatar
Re:Time for a Cam
Jaime,
I put a cam in my truck a few months ago and have a bunch of pictures and instructions to go along with them. I've been meaining to post everyting on here but just haven't yet.
Basically, it's not too hard of a job, but DO NOT attempt it without the Cummins tools or you'll be in for a nightmare. You have to be careful (and kinda lucky) to not drop a lifter into the pan while the cam or aluminum cylinder is out of the motor, but other than that it's just time consuming and a little tedious. If you do it, be careful when you pull the lifters up into the bores. The front lifter of every clinder has a tendency to want to get pulled up into a void in the block. You'll think that you have it in, but it's really in the wrong spot! You have to pull the bumper off, radiator out, move the A/C condenser, oil cooler, and tranny cooler to the sides, pull off the fan and then the front cover. On the top side you pull off the valve cover, rocker assemblies, and pull out the pushrods. One other trick... there's some plugs up under the cowl you can pull out to get the dowel rods down into the lifter bores to hammer into the top of the lifters. If you didn't know that they're there you'd never get 'em in. I'll try to remember to load the picture on here this weekend. Hopefully it'll help a little.
John
Old Aug 8, 2003 | 02:17 PM
hellotbone's Avatar
Re:Time for a Cam
A little to helpful I think I'll find easier ways to make some HP thats to involved and to into the engine for me.
gecoveyc
Jul 1, 2011 04:25 PM
etn550
Apr 1, 2010 12:12 PM
AH64ID
Jan 18, 2009 04:59 PM
82NDSNPR
Sep 27, 2007 12:25 AM
toy4xchris
Jul 7, 2007 08:05 AM
