Thinking About A Big Line Kit - Anyone Have Instructions?
Old Jul 9, 2007 | 11:20 PM
EverydayDiesel's Avatar
Im trying to make it as easy as I can on my VP44 so maybe it will last.
What is involve with installing a big line kit? Which kit should I get?
Old Jul 10, 2007 | 08:40 AM
D2 Cat's Avatar
Geno's has a big line kit. It includes the brass fittings which replace the five banjo bolts (which are restrictive). The hose, I think is 1/2" and fits on the fittings as you need them--you cut to length, lubricate and press on. Mount the pump back in front of your fuel tank. I installed a ball valve so I could shut off the fuel supply to change out the pump without a diesel bath. If you take your time, have a little mechanical ability figure 3-4 hours---or all day if you don't!! It's not a diffiult project. Cost including valve maybe $130
Old Jul 10, 2007 | 08:46 AM
johnh's Avatar
the big line kit will not help your vp electronics, which is a good percentage of vp failures but it sure won't hurt the internals
Old Jul 10, 2007 | 01:57 PM
Tocapet's Avatar
I put the short hose on the pump first before I cut the line. Then as soon as it separated, I jammed it on. Lost about 3 ounces. Most of that was what drained out of the line up to the filter. I caught that with an oil drain pan. If you're ready and quick, you get no diesel bath.
Old Jul 10, 2007 | 02:13 PM
hamilton71801's Avatar
As far as a diesel bath goes, I had to burn my clothes. Who needs instructions.
Old Jul 10, 2007 | 02:57 PM
coachgrowl's Avatar
I like the smell of diesel. seriously though if you let the tank get down to about a 1/4th it doesn't come out at least not on mine.
Old Jul 10, 2007 | 08:38 PM
91rangerturbo's Avatar
And the kit comes with detailed instructions.
Old Jul 11, 2007 | 03:32 AM
Ph4tty's Avatar
Vulcan Performance has some good line kits. He sells on ebay too.
Old Jul 11, 2007 | 07:02 AM
Joe Diesel's Avatar
my Vulcan was easy to install & a great price too
rxpx
Nov 25, 2014 09:13 AM
steelblitzkrieg
Nov 26, 2010 12:41 PM
shortie
18
Feb 16, 2009 08:27 PM
Mechanos
Jan 22, 2009 11:25 AM
RobV2500
Nov 1, 2008 05:05 PM
