Is there a way to tap the pump
Old Sep 3, 2008 | 08:54 AM
bridleman's Avatar
Is there a way to tap the pump so that it doesn't void the warranty and clip the wire?
Old Sep 3, 2008 | 10:05 AM
Diesel Doc's Avatar
BD stealth cover
Old Sep 3, 2008 | 04:22 PM
Dinner's Avatar
Originally Posted by Diesel Doc
BD stealth cover
I think they have caught onto this "stealth cover" haven't they though?
Old Sep 3, 2008 | 04:27 PM
AggieJustin's Avatar
Depending on how closely the warrantying vendor wants to look, any piercing of the pump wire will be visible.
The stealth covers work by inserting a tiny pin into the wire. This method is much less visible than pinching a scotch-lock on the main part of the wire and cutting the insulation. But if the vendor looks close enough, they'll be able to identify the tell-tale mark where the wire was pierced by the cover.
Any "tapping" of the wire puts you into the "pay to play" category.
Old Sep 3, 2008 | 06:32 PM
rage_blue's Avatar
Watch the dabs of paint they put on the screws, you may be able to clean it off then put some back on if you need waranty.
Old Sep 3, 2008 | 07:56 PM
J Lent's Avatar
I just sent a vp to II which is 2 months old & has pump tap soldered on. Brady said that he will repair it for me under warranty, but he wouldn't just send me a new pump because of the tap. He is very good with his warranty, as long as you have a good lp system & pump damage wasn't caused by inadequate fuel flow.
Old Sep 3, 2008 | 11:23 PM
bridleman's Avatar
I am not trying to sneak by the warranty per se I just didn't want to damage the wire so bad that it would cause me problems in the future if something happened.
Old Sep 4, 2008 | 01:46 AM
Diesel Doc's Avatar
The stealth cover I have dosn't tap the wire at all. it screws down onto the post the wire is atached to under the cover and then your box wire ataches to the stud on the cover.
Old Sep 4, 2008 | 09:20 AM
bridleman's Avatar
thanks guys
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
alto22
34
Feb 16, 2007 09:28 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
