Switch to enable both high/low beams at once?
Old Jan 16, 2005 | 09:36 PM
caper's Avatar
Is this just for non-sports or will it work with an 02 sport ???????
Old Jan 17, 2005 | 12:03 AM
2500CTD's Avatar
The guy that did this I believe his screen name is rattlerattle. Going to do it to mine also. here is the link https://www.dieseltruckresource.com/...t=rattlerattle
Old Jan 17, 2005 | 08:50 AM
upersleder's Avatar
just did this on mine, took five min. and worked great. while i was at it i put some of those sylvania silverstar headlights in. it made a big difference, not sure it was worth $40, but if i miss a deer i guess it will be.
Old Jan 18, 2005 | 08:41 AM
CTD NUT's Avatar
I did RR's low beam mod awhile ago and it works quite well, I also use the silver stars.........Brite box and RR both say that the bulb life does not seem to be compromised with both the high and low beam on.........I have not had any bulb issues to date either.....
Old Jul 22, 2014 | 03:02 PM
brantner22's Avatar
PLEASE HELP!!! I have no highbeams!!!!!!
I know this post is like 9 years old and I'm hoping that someone still read this...
To: Silerram 323..or anybody else that may have knowledge on it...
I have read your post and thought it would be the conclusion to my problem, however when I looked for these wires I was able to locate the violet wire with a white strip. But the two "light green" wires that you speak of aren't there. I have a green with a black strip and a green with a light blue stripe. My model is a 2003 and yours was a 2002. Both are the same generations I believe so I wouldn't think it would have different wires. I've tested both green wires and neither appear to be attached to the headlights.
Here's why I need my low and high beams to work together. I decided to do my own retrofit projects. But I did not buy the kit because it was over $300 and all together I only spent $80 for both the projectors and HID's. But anyways I used an H1 bulb for the headlights because that's was the projectors called for. I hooked my low beam up to the HID and the high beam up to the cut off in the projector. Not thinking..I forgot when you turn your high's on the lows go out. So now my light goes completely out but the cut off's in the projector are engaged like they are supposed to be. So now I need to figure out how to be able to use my low beams with my highs. I tried the mod you posted, but for the life of me I can not figure this simple thing out. I see other guys have done it with no problem. If anyone has any pictures of how they did I it would be greatly appreciated!!!
Old Jul 22, 2014 | 04:14 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
02 truck is a second gen, 03 is a 3rd gen wiring is different.
Old Jul 22, 2014 | 07:38 PM
brantner22's Avatar
ok thanks..well hopefully I can figure something out. Does anybody else know how to wire or make a mod so the low beams and high beams work together at the same time? This will be for a 2003 Ram 4.7...any help will be GREATLY GREATLY appreciated!!!!!!!!!!!!!!!!!!!
Old Jul 23, 2014 | 11:48 AM
Admin Team Leader
Why don't you spend the money and buy a service manual from Geno's so you have the necessary wiring diagrams?
nfc90
Oct 28, 2019 04:24 AM
Tyeopalinski666
Jan 16, 2014 03:59 PM
handymantim
16
Jul 30, 2012 12:34 PM
vtec_vigor
21
Jun 6, 2010 12:37 AM
mamm7215
19
Jun 4, 2004 09:39 AM
