Supercharger
Old Apr 22, 2003 | 11:38 AM
Cumminsdieselboy's Avatar
Muted User
Supercharger
I have a Kawasaki Mule 2510 Diesel. Little 3cyl. naturally aspired diesel. I was wondering if I put a little electric fan in the in take would that be like a little supercharger?
Old Apr 22, 2003 | 02:32 PM
hellotbone's Avatar
Re:Supercharger
I doubt you can make enough air from a fan to make it worth while.
Old Apr 22, 2003 | 02:33 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Supercharger
AWWW Heck.....jes' put a nitrous bottle on it.
Old Apr 22, 2003 | 03:33 PM
BigBlue's Avatar
Re:Supercharger
Get an import turbo. You've only got 1 less cylinder than they do.
Old Apr 22, 2003 | 04:48 PM
SjLingenfelter's Avatar
Re:Supercharger
Old Apr 23, 2003 | 03:12 AM
Bart Timothy's Avatar
Re:Supercharger
Try here http://www.electricsupercharger.com/
Old Apr 23, 2003 | 07:46 AM
Muted User
Re:Supercharger
What About something cheap that I can do at home?
Old Apr 23, 2003 | 08:06 AM
hellotbone's Avatar
Re:Supercharger
Hook up an O2 bottle that can give it a little puff.
Old Apr 23, 2003 | 09:01 AM
Mexstan's Avatar
Re:Supercharger
This thread got me thinking. No, I don't think adding a fan will do anything for you, and in fact may restrict the airflow. If a fan is to work it will probabaly have to be a big ducted fan. So then the question popped up in my small mind, how would one find out if any fan would work in this application? How does one easily measure the volume of air in the intake manifold? So here is a crazy Heath Robinson (Robertson?)suggestion. Get an old aircrcraft air speed indicator (ASI) from a wrecker and place the pitot tube in the manifold. That airspeed should give an indication of the amount of air going thru. Then place the pitot tube in the airstream of the fan you want to use. The indicated airspeed should be considerably higher for the fan to be effective as a supercharger.<br>OK you guys with more technical knowledge that I have: will this work as a rough indicator or am I all wet?
Old Apr 23, 2003 | 09:15 AM
Mexstan's Avatar
Re:Supercharger
On further thinking about this in the shower I had another idea. Maybe a boost gauge would work in lieu of the ASI. Just make your own pitot tube out of a piece of 3/16 pipe. Accuracy is not important, as these are just comparison figures.<br>Have no idea if this would work. Just throwing out a crazy spur of the moment suggestion. However, if anybody tries this, would love to hear the results.
Old Apr 23, 2003 | 09:30 AM
97CTD's Avatar
Re:Supercharger
you can make a helluva electric supercharge out of a leaf blower!!!
Old Apr 23, 2003 | 09:53 AM
hellotbone's Avatar
Re:Supercharger
ASI works off static and pitot mexistan, your talking to a pilot now so I would have to say it would be a real bugger to get accurate readings with an aircraft ASI. You know there is a huge dependence on the lenghts of hoses and orfices and such in an airplan to make it all work accurately. I had my Dehavilland Beaver in the other day for a Pitot/Static probelm got a tiny piece of dust in there and made everything get screwy its pretty tough to accuratly measure the intake velocity with an ASI.
Old Apr 23, 2003 | 10:15 AM
Mexstan's Avatar
Re:Supercharger
The problem with your DHC 2 could have been in the static system. Also on the ASI system as used on the DHC 2 a bug such as a spider in the pitot can cause havoc. Waxing your aircraft and getting wax in the tiny static hole is an example of what can cause a problem in accurate reading. The crazy comparison I proposed is not dependant on a &quot;balanced&quot; system of pitot and static. Accuracy is not the factor here, only a comparisom measurment that has no relevancy to accuracy. Length and sizing of hoses is critical to an aircraft pitot/static system but would have no relevancy to the rough comparison test I proposed.<br>Well????<br>
Old Apr 23, 2003 | 10:25 AM
hellotbone's Avatar
Re:Supercharger
Agreed with that the DHC2 did have a tiny bit of dust what a bugger eh! Oh well you are right if you plan on it with low margins of accuracy then your way will do just fine.
Old Apr 23, 2003 | 10:32 AM
Mexstan's Avatar
Re:Supercharger
Jamie, out of curiosity what is the S/N of your DHC 2 and what mods have been done, such as 3 blade prop and large baggage compartment?
mhuppertz
Dec 17, 2005 07:45 PM
trik396
Dec 11, 2005 07:28 PM
gerry
Aug 19, 2005 07:35 AM
hotdram
Apr 13, 2005 12:17 PM
Battering Ram
19
Apr 24, 2003 02:11 AM
