View Poll Results: Which turbo?
Super B
21.43%
HTB2
78.57%
Voters: 28. You may not vote on this poll
Super or HTB2, please vote
Old Jul 12, 2007 | 04:31 PM
rootremblay's Avatar
Cool Super B or HTB2, please vote
The Super B has a 62mm wheel and 12 cm housing and a kit with downpipe retails $1,265. The HTB2 also has a 62mm wheel and a 12 or 14cm housing and their kit retails around $1,400. what do you guys think?
Old Jul 12, 2007 | 04:49 PM
dieselrob's Avatar
What do you do with your truck, and are you going to put more mods on it. Id go with the htb2 because you can upgrade housings and wheels if needed and they have a better array of choices.
Old Jul 12, 2007 | 05:52 PM
clutch1's Avatar
HTB2 for my vote
Old Jul 12, 2007 | 05:53 PM
clutch1's Avatar
why no II? they are also a good choice
Old Jul 12, 2007 | 06:13 PM
TxDiesel007's Avatar
Agreed here
BUT with the choices given, id say the Killer B2 is the better choice overall..
Rick
Old Jul 12, 2007 | 07:11 PM
Im learnin here yall be patient the Sper b and htb2 are the pnly ones I have researched thats why no II. Maybe yall could school me a little?
Old Jul 12, 2007 | 07:19 PM
clutch1's Avatar
the phat shaft line are the ones with the smaller wheel like the HTB2, then you get in the super phat shaft which is the same as the High Tech 71 series with the bigger wheel. both can be in the 62/12 or 62/14 configuration.
Old Jul 12, 2007 | 08:08 PM
So you can get the phat or super phat with a 62mm wheel?
Rodram2002's Avatar
Who's super B is this? I am sure the super b's are a 57mm compressor. Call High Tech Turbos, they will know for she. The HTBG they sold was basicly a super b and is a 57mm compressor.
Old Jul 12, 2007 | 08:38 PM
I called BD and they said it was a 62. but heck i dont know, thats just what they said
Old Jul 12, 2007 | 08:48 PM
Rodram2002's Avatar
I guess they are a 62 then. my bad.
Old Jul 12, 2007 | 08:52 PM
clutch1's Avatar
remember the compressor housing and the wheel are two different things.
Old Jul 12, 2007 | 10:27 PM
tony597fitter's Avatar
I would say the super phat shaft 62 and the HTT 62 with the 71 wheel would be to big for your fueling setup. You will need bigger injectors, to get her to spool fast.
I thought we all had this figured out last night?
Old Jul 12, 2007 | 10:30 PM
Like I said last night in the other thread, you should be able to pick up a HTT 62/14 with a 4" downpipe for under $1200. I got mine for $1165 shipped and that was with the downpipe.
Old Jul 12, 2007 | 10:45 PM
Tate's Avatar
The regular Phat Shaft 62 or HTB2 instead of the HT71 units might be more appropriate if your dyno numbers in your sig are current. With my truck, the SPS62 doesn't really come in till around 1800 rpm. A tighter housing would probably be advantageous, especially with an auto. If you've got more fuel since then, the bigger turbine would be better. My 62 doesn't come close to cleaning up the smoke anymore with whats in my sig.
