Stock turbo??
Old Sep 2, 2009 | 07:16 PM
Lisleche's Avatar
Stock turbo??
I have a 2001 3500, 24v. It had the stock turbo and it was going bad.. I was hoping to get it rebuilt but its taking too long and was wondering if a HX40 would work. I am not a machanic and do not know what the stock turbo was. Any help (education) would be appreciated. I was thinking about upgrading but not knowing what that involves and on a limited budget.
Old Sep 3, 2009 | 12:05 AM
DodgenIt's Avatar
With your 01 Auto I believe you had the HY-35. Its about the smallest turbo they put on these trucks. Only the 01 and 02 auto's had them I believe.
Thats whay I had on mine with a j-hook on it till I got my Hybrid put in last weekend.
If your lookin for a good deal, Shop around for a used HX-35. Its a direct bolt up and will improve your air intake enough to run your comp box with injectors with no problems I think. Watch your pyro but it will still be better then the HY.
You could do a HX 40, I think you might have to change the down pipe with a 40 though, Im not sure about that. But your fuel mods would be enough to spool either HX 35 or 40 with a 12 or 14cm exhaust housing. IMO-In my opinion
HTH. - Hope this helps.
Ian
Old Sep 3, 2009 | 09:32 AM
Lisleche's Avatar
Yes it does! Thanks!
Old Sep 7, 2009 | 04:03 PM
pokapotato's Avatar
HX40 you will need a different down pipe. If I were you I would buy a used hy35 on ebay or get yours repaired. You won't find another turbo that will spool faster and for your mods it builds enough boost with a J-hook......unless that is a Smarty in your Sig, in that case it might be better to step up to an hx35 or hybrid.
Old Sep 7, 2009 | 08:24 PM
Fern's Avatar
My vote is HX35 if your on a limited budget.
Old Sep 8, 2009 | 11:34 PM
DodgenIt's Avatar
Yea the hx35 for sure. True nothing will spool like the HY35 but the HX with a 12cm housing wont be much slower. And it will for sure help with EGT now and future.
If your gonna spend a few hundred on an HY, might as well spend 100 more on a HX for the upgrade factor. IMO
Old Sep 8, 2009 | 11:59 PM
heykw's Avatar
buy a used 62
Old Apr 19, 2010 | 10:37 PM
Lisleche's Avatar
Thanks for your input, I did get an hx-35 , but a foreign made one. It is now going out again.. I am thinking of going to the hx-40 even tho i would have to get a new down pipe. I am wondering now tho if there is something wrong with my mods.. my edge box is problematic and needs to be replaced.
Old Apr 20, 2010 | 04:09 PM
birddoctor's Avatar
I'm having the same problem with my edge box right now.Its acting up every now and then.Gonna unplug it before it fries something thats expensive.
Old Apr 21, 2010 | 06:02 PM
Lisleche's Avatar
I had to unplug it because it would either not turn on.. or not turn off... or turn on all the way.
Old Apr 21, 2010 | 09:16 PM
Nick02Ram's Avatar
So what's the deal with these eBay turbos? I typed in HX40, and they had a bunch of "brand new" turbos for like 300 bucks, there's no way these are for real, right?
Old Apr 21, 2010 | 11:39 PM
Lisleche's Avatar
it is for real.. i purchased one.. they are not the quality of the true holshot tho.. it was ok for me to use in a financial pinch.. but as you can see.. it lasted me about 6 months...
Old Apr 24, 2010 | 07:36 PM
Lisleche's Avatar
I have noticed down pipes for the hx40 that can be ordered. Any brand suggestions.. i have seen (silverline, diamond eye, and one on DKdiesel site)
Old Apr 24, 2010 | 07:58 PM
DodgenIt's Avatar
Lisleche, Im happy with my silver line system. Most will do fine.
Nick.. DO NOT BUY ONE!!!
They are total junk. About a year ago when I was looking to upgrade from my stock turbo, I ordered one of those from ebay.
When It got here I noticed it didnt have 'HOLSET' anywhere on it. I called em about it and they told me something like, Its a Borg Warner cast to Holset specifications. Totally bogus! I couldnt believe it.
I sent it back and it took 2 months and 20 phone calls to get my money back.
And Im not the only one this has happened too, Les's only lasted 6 months..
Industrial told me they get guys all the time that bought one and killed it and needed it rebuilt, but they cant cause is a Mut POS.
Shop around, get something with quality, and feel free to ask anyone on here what is thought about a certant brand. We're all here to help each other.
HTH Ian.
Old Jul 22, 2010 | 05:53 PM
Lisleche's Avatar
Ok.. have a rebuilt hx40 and down pipe.. looking at the original pipe and the original pipe is longer than the pipe recieved.. not the easy bolt on situation I was told when purchasing the down pipe. The pipe is 4" thorugh out and I am thinking I may have to get a transition pipe to hook up to the original pipe prior to the cat. any thoughts ?
