Starter problems, Maybe?
Old May 16, 2007 | 07:41 PM
CapnRam's Avatar
Ok went out this morning to start big red and nothing, power everything but nothing, so hit the key a couple more times and bammm fires up... start it a couple more time today no problems, then all the sudden go to start and nothing, clicks but nothing, so i cycle the key a couple of times then it tries to turn over, like a 1/2 turn over then nothing, hit the key again and bamm fires up?? Is this a starter problem, or a solenoid? or what? any one had this problem before.... come on throw me a bone or something to work with on this..thanks
Capn
Old May 16, 2007 | 07:45 PM
Mountaineer's Avatar
My bet it's the solenoid contacts. Mine did the same thing and thats what it was.
Old May 16, 2007 | 08:34 PM
arcc's Avatar
Do a search on the starter contacts. You can get them from Foster Truck I think and change them cheeper than a new starter. Thats what I had to do to mine. They were worn pretty bad after 90000 miles.
Old May 16, 2007 | 09:10 PM
dgm1958's Avatar
it's the starter fix it either way (new starter or contacts) but fix it before it does to you what mine did. mine started out like yours then one day I started it and the starter stayed engaged couldn't shut it down put it it in 5th stalled it out put in clutch starts back up the only way to shut it down was unhook the both batterys
Old May 16, 2007 | 10:09 PM
superuke's Avatar
Starter
Had the same problem, got my kit from Napa, around $20 Canadian.. The kit contains 2 copper posts, new plunger, & a gasket for the solenoid. Dodge don't carry the parts, but wanted to sell me a new starter, around $500 installed .. I don't think so.. hardest part is getting the starter off & on.. putting the kit in 15 minutes. works as good as new, oh & to take my starter off I had to get torx wrenches.
Old May 16, 2007 | 11:40 PM
smokinstrokes99's Avatar
contacts, my 12 valve did the same
Old May 17, 2007 | 07:13 AM
CapnRam's Avatar
So these contacts are in the starter? And i'm taking it, you can just buy a contact kit from a auto parts store? Thanks for all the info, guess that will be tomorrows project, now this truck does have 173k on it, and i did look at the starter last night, and it looks original, but you can never tell, called the local store 200.00 for starter and 190.00 core on it!!! they must want that one back!! So should i just go get another starter or change out these contacts?? thanks again..
Capn
Old May 17, 2007 | 07:32 AM
http://www.fostertruck.com/dodge/default.htm
These are better than what you will get at a local auto parts store.
Old May 17, 2007 | 07:46 AM
Muddin_dude06's Avatar
Mine did that to me for about 2 months, it eventually got so bad it could take up to 15 minutes to get the dang thing to start. Like everyone said its the starter contacts, most kits are $20-$30 plus shipping and I got a brand new starter with a One (1) year warranty for $110 shipped. IMO if you have more than 100k miles I'd just get the new starter, I could tell a huge difference in actual starting power with a new one because the motor on the old one was getting worn. The starter I bought is very good quality also...
Old May 17, 2007 | 07:48 AM
mcoleman's Avatar
I second the Larry B's contacts. Huge difference between them and auto parts store stuff.
Old May 18, 2007 | 01:53 PM
CapnRam's Avatar
THanks for the info, I did go get a reman. starter from Napa, then got home and had the link for the super contacts, so ordered them, when they come in i'll install and if no more problems i'll take back this starter... yea 200.00 with a 2 yr warranty... one place was 200 with a 200 core!!! Holy Hanna...must want them starters back!! Thanks again... this forum ROCKS!!!!
Capn
Blowndodge
Sep 14, 2011 02:38 PM
FMB
Nov 14, 2010 09:09 PM
90ctd
Apr 2, 2008 08:27 PM
Haulsmytoys
Aug 15, 2006 10:04 PM
Paradise Racing
Jan 18, 2005 09:08 AM
