star wheel info please
k im new to 12v's. i have a 96 12v drw club cab 8ft box i was woundering pro's and cons to turning my star wheel towards the block with out moving to replacing the fuel plate? im headin to texas to pick up a 9k 34' road king and was thinking about doin it, i have egt boost and trans gauges.
thanks for any info
thanks for any info
no, mine is turned enough that i can't get the screw driver on it anymore because it is under the housing. And it is easy to adjust so if you don't like it, or you want to turn it more just carry and 8mm allen, and a screwdriver and adjust as you go. Careful not to loose the sealing washer under the plug though!
jdr160
Jan 12, 2008 07:05 AM
b.white
Mar 4, 2007 11:52 AM
