5000rpm 12v...
Old Apr 12, 2007 | 11:47 PM
Muddin_dude06's Avatar
5000rpm 12v...
Hi all, I know that PDW sells a 5GSK for $175 but what all else is needed to safely turn those RPM's? I am only really looking for 4500-4700RPM... But a little extra potential is ok Are 60lb. Valve springs stout enough or would custom springs be needed? Other than that what other add-ons are necassary? I would also install a Fluidamper to help keep harmonics inline Thanks everyone!
Old Apr 13, 2007 | 12:08 AM
Mav's Avatar
Mav
Id like to know as well, also on a 24v (sorry I dont mean to jack your post)
Old Apr 13, 2007 | 12:21 AM
WUnderwood's Avatar
5000 RPMs out of a 12 valve? wowzers
Old Apr 13, 2007 | 01:10 AM
wcbcruzer's Avatar
I'd say yes for a play truck. No for a daily truck. Sounds like something's gonna break.
Old Apr 13, 2007 | 03:30 AM
TheBigNasty's Avatar
I don't see anything over 3000-3500 being useful unless you are sled pulling where you need the rpms, and you don't exactly have a sled pulling clutch. Don't feel bad though, I don't either.
Old Apr 13, 2007 | 03:36 AM
PourinDiesel's Avatar
Balance, fly cut, billet cam, pump work$$$, cam retainer, girdle, studs, fire rings, water relief, valve train, etc. etc.
Old Apr 13, 2007 | 04:15 AM
cumminsdriver635's Avatar
On a stock cam all you are doing after 3k rpms is making heat But man they sound good at 4k and up
Eric
Old Apr 13, 2007 | 05:01 AM
Forrest Nearing's Avatar
definately get some high quality retainers and locks... the stockers like to try to pull the keepers through the retainers at high RPM!!
Old Apr 13, 2007 | 07:14 AM
ckt_santiago's Avatar
To hold things together ^^^ is correct. The list really is longer than that too (as the "etc. etc." would suggest).
Old Apr 13, 2007 | 08:44 AM
timbeaux38's Avatar
5k is not really hard to get to with a 12v. This one let go at 7710 per the taddle-tale button.
Click here to see Video
Old Apr 13, 2007 | 09:18 AM
megajoltman's Avatar
Man that thing sounds wild
Old Apr 13, 2007 | 10:59 AM
Bobcat698's Avatar
That was a bad day.. It was crazy to see in person.
Old Apr 13, 2007 | 11:44 AM
BigBlue's Avatar
WOW!!! That was cool. Not cool that he just destroyed a very expensive engine but cool watching it do it. How'd it hit 7700 rpm?
Old Apr 13, 2007 | 12:56 PM
signature600's Avatar
When it's setup and has the power to spin to 6K under load, then all at once the load comes off the engine, they will over rev really fast!!!
I think he broke the Ring and pinion on that run, and then the engine over revved and blew...cause and effect kind of deal! At least that's what I think I remember from that pull!
Chris
Old Apr 13, 2007 | 01:38 PM
joefarmer's Avatar
The tranny failed and now you can put your head through the hole in the block.
brnaond.
